121 - 140 of 203 Posts
Discussion starter · #121 ·
Latest update isn't anything special. Just installed the TPMSD unit and spent time commuting to see if it worked. Turns out it works as advertised, and in the hundreds of miles since it was installed it has not given me any trouble. I haven't been focusing on the CR-Z lately due to more pressing concerns about the CRX's suspension and will hold off on the CR-Z for a while due to budget constraints.
The parts I want for the CRX are not cheap nor are they easy to come by. The dampers I found were only because of a good recommendation by my great Japanese friend Tamura-san and me stumbling upon a post in Japan of someone who bought a product Tamura-san recommended. With his experience he recommended European suspension companies, and the product I found was made by Bilstein. I ordered it through my parts exporter in Japan and they were delivered only a few days ago. But I still have a long list of things to buy including bushings, torsion bars, sway bars, rear springs and more. It will cost thousands of dollars but it will truly be unique.
After the CRX parts, I plan on buying two or three CR-Z parts. But before that I'm planning a trip to Japan! I made a good number of friends out there and I won't let an opportunity of a lifetime go to waste! I will update if I happen to do something fun like autocross but it might be a while.
Discussion starter · #122 ·
Last week I finally replaced the Bridgestone RE980AS tires I've had on for years, since probably 2017. They lasted to the warranty even after thrashing them on both the full length road course at Brainerd International Raceway, a full day of autocross practice and a couple more autocross days. I changed over to Goodyear Eagle Sport All Seasons in 215/45R17, same size as the Bridgestones I installed. The Goodyears have less road resistance and get a small but noticeable bump in fuel economy. However, wet traction is sub par. Putting around is fine but pushing even remotely hard on the throttle will just make the wheels spin even in light rain.
If you want cheap tires, order through the VCS store at any VA hospital. They give you prices much better than tire shops, no state sales tax applies, and you still get applicable rebates! When I showed up to the appointment at the Goodyear store, they were missing the last tire. I ended up waiting three hours but they didn't charge me at all for install. I saved several hundreds of dollars so even though the tires are mediocre in the wet I'm pretty happy.
Pics are of the worn out old tires and the new Goodyears.
Nice car! I'm considering doing the super charger route instead of the kswap. Any tips to be aware of or things you'd need for the supercharger addition? i'm pretty sure an ECU tune is necessary but anything else that should be done along with it to prevent fututre issues?
Discussion starter · #124 ·
The HPD supercharger kit includes virtually everything you need to install it, just make sure to get the traction fluid separately. The greatest benefits of this kit are reliability and parts availability. The only failure this car has suffered with the supercharger was that boost leak. It's not the fault of King Motorsports, just terrible luck. If you wanna run E85 a full fuel system upgrade would be in order though. If yours is 2011 or 2012 definitely get the Hondata system for tuning. But if it's 2013+ like mine your only option is Ktuner. Hondata is much better. Keep in mind that the HPD kit is technically listed as an accessory and therefore CANNOT BE RETURNED OR REFUNDED so you will be going past a point of no return.
I guess the only real recommendation from me is to install an LSD and do NOT install a new final gear ratio. It screws with the IMA system and you lose regen. I'm currently waiting on a solution for that. A very handy but expensive addition would be gauges and gauge pods for diagnosing potential failures in the future. They were very helpful when the boost leak occurred since there was no CEL and only a loss in power.
However, if you are serious, get this kit while you can. And get all of the other parts while you still can. Several of the parts I have on mine are long since out of production and impossible to get again. Happy tuning. 👍
Discussion starter · #125 · (Edited)
For a few weeks there's been a very annoying noise from the right rear. The bearings seemed fine so I thought it was time to do the brakes. I bought the EBC brake pads and rotors along with a handful of OEM Honda hardware. Coming from up north the climate took a toll on the car with lots of rust on the calipers, so it was possible that it was siezed or the pads wore out. The rear brakes had never been serviced since new so that was definitely possible.
It took a bit longer to do the brakes due to the corrosion but it all eventually came apart. I installed brand new slide pins and lubed them thoroughly.
One of the pins on the right side had much more resistance than the rest. When putting the new pin in I added even more grease and kept sliding it until it became smooth. When looking at the brake pads I finally discovered the cause of the problem. One of the ears of the pads was rusted onto the tab of the hardware. This meant it was sort of hinged and applying pressure unevenly. And it just so happened to be the pad that had the squealer and pressed down on the one side of the pad where the squealer was. I guess that was a little lucky. I installed new hardware here too.
That caliper wasn't in very good shape either. The left side boot was intact, but this side had a very torn boot. Unfortunately I didn't anticipate this so I didn't order one, nor have I ever rebuilt a caliper before. I think once it's time to do the brakes again I'll just order brand new calipers. I don't live up north anymore so I won't need to worry about further corrosion.
I got the new pads, rotors and hardware all installed and torqued to spec. I've been driving it for a few days and so far there has been a noticeable difference. It's just the rear but I can feel the brakes have become more responsive and the pedal is slightly less squishy. I didn't even bleed the brakes!
These came with a black coating all over the rotor. But once I sprayed them with brake cleaner that coating basically melted away. I'm not sure if that's supposed to happen or if I wasn't supposed to use brake cleaner. Oh well. I'm still happy with the upgrade.
Discussion starter · #126 ·
Welp today Instagram banned me. Not sure why. I barely post on there compared to most and I don't post much else other than car stuff. It's really dumb. I'll try to appeal but who knows how that's gonna go. :/
Discussion starter · #127 ·
A few things happened recently, all pretty good things. My Instagram account is now back up and no longer banned so that's neat. While browsing Mugen's order system page I saw that the ZF2 Mugen front sports grille was marked as sold until out of stock, meaning they have some left but won't be making any more. So I ponied up some cash and ordered another one incase my current grille gets damaged. Might as well if they're never being made again.
I just sold my clutch kit to someone on Facebook marketplace. He said he was doing a manual swap on his car that happened to be the same model year as mine. He paid for shipping and fees so this kit will get a second life in a different car somewhere in the east coast.
I happened to make an interesting discovery yesterday too. I found that Honda made car covers for CR-Zs equipped with rear wings. It's supposed to fit the 2016 car because of its optional Modulo wing but it should fit mine with the Mugen wing no problem. I bought one from Japan for only $114 before shipping and fees. These are the pictures from the auction:
After looking up the part number I found pictures from another listing with the cover installed:
Once it comes in I'll update this thread and make a separate one for other readers.
Discussion starter · #128 ·
Just this week the cover came in. It was brand new in the plastic packaging.
I took a picture of the part number for those who want to try finding one for themselves.
It also came with a generic manual.
It comes in the form of a tote bag. It is not a separate piece, it really does unfold as part of the cover.
After unfolding it and draping it over the car it looks exactly as advertised. It fits the car quite snug.
Because my car has the Mugen wing instead of the Modulo wing, mine is slightly larger. But after putting it on it still fits really well, and it only rides slightly higher up in the rear.
The bottom of the back just barely clears the diffuser. But if I tug on it a bit it will clear and it can be tightened up. All in all it was a worthwhile purchase and I would recommend it to someone as long as their wing was no larger than the Mugen wing.
The Max Orido Nardi wheel has finally arrived from Japan, and it arrived the day the AMS carbon wheel got back from the upholstery shop. I’ve never seen a real Nardi wheel before but I am in love with it. It’s similar to my Mugen Racing III wheel made by Momo, but it somehow feels just a tiny bit nicer.
As I noticed Orido was signing some wheels I did request my exporter in Japan ask for it to be signed. Lo and behold he delivered with a signed box and a signiature on the spoke of the wheel itself! Among all of the extra goodies the wheel came with it feels quite special to get a limited edition item from one of the famous drivers from Hot Version - I doubt many of these wheels made it to the US.
Anyways, I’ll dump all of the pictures for your viewing pleasure.
View attachment 65731 View attachment 65732 View attachment 65733 View attachment 65734 View attachment 65735 View attachment 65736 View attachment 65737 View attachment 65738 View attachment 65739 View attachment 65740
Nardi Torino :cool:
Discussion starter · #130 ·
Nardi Torino :cool:
Yes sir. Made in Italy.
I might possibly be buying another limited edition Nardi wheel. Just depends on if I can justify it. I still have to secure the rest of the Mugen aero parts and some other stuff. Here's the other wheel I want:
Discussion starter · #131 ·
Got a somewhat exciting update for everyone. I am officially ordering the remaining pieces of the Mugen aero parts! Earlier this week I paid for the front under spoiler (front lip), rear under spoiler (rear diffuser), the aero illumination kit (meant for the S660 and N-Van), and Honda OEM reflectors. I'll explain a little bit by using some of the stuff from my separate posts.
For the front, it will match up exactly as intended. I have a ZF2 so that's obviously the one I'm getting from Mugen.
For the rear, I'm picking the ZF1 Mugen diffuser even though my car is not a ZF1. I picked this for a few reasons. The way it is disassembled for painting means that the plate on the inside of the mesh grille on it can be removed. However, there seems to be no harm in leaving it off and letting air flow through it. Lots of Honda guys like drilling speed holes in their bumpers to reduce drag, so just leaving this plate off will achieve a similar effect without looking janky. I also prefer the look of the ZF1 diffuser to the ZF2 diffuser.
The other reason is because I have the Mugen ZF1 sports exhaust system. The Mugen ZF1 diffuser has specific instructions on trimming the diffuser around the ZF1 Mugen exhaust system. Mugen absolutely thinks of everything and I love it.
Now, I'm gonna make a short post from my other thread about this specific kit. So, for the illumination kit. The CR-Z kit is discontinued. Can't get it anymore. But the kit for the S660 and N-Van is virtually identical. Because I can't find anyone else who's ever attemped to makeshift this kit to work with a CR-Z, I'm gonna give it a shot myself. I would rather try something and fail than nevet try at all and regret not doing it every time I remind myself.
CR-Z Aero Illumination Kit parts list:
S660 and N-Van Aero Illumination Kit parts list:
Wiring schematic for the CR-Z:
Wiring for the S660:
Based on the wiring and parts list it should most likely be able to be retrofitted to work with minimal modification.
As for a life update, I will be leaving for the Navy. I decided to join the military because I got kinda bored working a regular job. I won't be able to share progress with the forum regularly anymore. But I will at least take pictures and attempt to wire the harness up just to see how it works.
Discussion starter · #132 ·
I just asked for a picture of the boxes from the parts exporter in Japan. As proof, here they are! As I suspected these boxes are huge because the parts span the width of the car. All we need to wait on is one more item and it gets shipped out. After this, the final parts kit will be the side skirts.
Discussion starter · #133 ·
As a note for future reference, I'm going to note the Mugen parts that I have planned and acquired so far because my build's exterior is mostly focused around them as they're the best.
Mugen Parts currently equipped:
Mugen Rear Spoiler (discontinued)
Mugen Front Sports Grille (plus one extra, discontinued)
Mugen Sports Exhaust System (ZF1, discontinued)
Mugen Formula Shift Knob (discontinued)
Mugen NR Wheels (discontinued)
Mugen Sports Pedal Kit
Mugen Green Oil Filler Cap (super rare, discontinued)
Mugen Parts acquired for later installation:
Mugen M7V2 Wheels (15 sets produced, discontinued)
Mugen LHD Front Sports Mat Set (discontinued)
Mugen RZ Rear Luggage Mat (discontinued)
Mugen StepWGN Number Plate Bolts (mega rare, discontinued)
Mugen Titanium Emblem (discontinued)
Mugen Parts paid for:
Mugen Front Under Spoiler
Mugen Rear Under Spoiler (ZF1)
Mugen Aero Illumination (S660/N-Van but should work)
Mugen Parts yet to buy:
Mugen Side Spoiler
Even though I moved states and have much higher expenses living on my own, I was still able to get more parts before they get discontinued and become unobtanium. However, soon I will be enlisting in the US Navy and all I have to do now is sign a contract and get a ship date. I will still come back to finish the car and have it kept with my roommate who will take care of it while I'm away and on deployment.
Mugen Side Spoiler
Amazing! Your CR-Z deserve that "MUGEN" badge and also in the car's project name.
Discussion starter · #135 ·
Thanks mate. I don't think it's there quite yet though. I still want to be able to install all of the parts before I give it a big label or name. Still, I am considering buying the Mugen Dry Carbon Emblems, probably a pair of them. But the side skirts come first. Paired with some genuine carbon fiber parts from Japan I think it'd look pretty cool. I am leaning towards the J's Racing full carbon hood but we will see how this plays out over the next few months after bootcamp.
Discussion starter · #136 ·
Got the Mugen parts in the mail last night! The box was pretty rough but fortunately the parts inside were still intact. At first when I started using they were pretty good, delivering was on time or sometimes early, and the packaging was perfectly intact. Now they're getting here late and the boxes are getting destroyed. Considering their prices I would rather pick a different courier if I had the choice but this time I didn't due to oversized shipping.
I've already dumped these pics so I don't feel like typing everything out again so I'll just post the pics in this thread.
Discussion starter · #138 ·
Welp, I signed my contract with the Navy yesterday. I got the job I wanted. CTT, which is Cryptologic Technician Technical. I got the full $25k bonus and a $3k bonus for college credits. I will be leaving for boot camp on March 8th to start training leaving civilian life behind. 👍
Discussion starter · #140 ·
A few weeks ago I hit some debris in the road. The side skirt popped off and dragged across the highway for a while before I realized it was loose. So I took the day off to bring it to a body shop next to my friend's repair shop. Because the car is gonna have the Mugen parts installed I just asked him to only use black primer because the side skirt will just end up getting replaced anyways.
Today I got to pick it back up and have it installed. Aside from more of the part being covered in primer than expected, they did a good job. So I'm happy with their work! He put some new clips in it and let me go on my way.
I also brought the Mugen front under spoiler with to show him what the part looks like and what to expect. He's an older hispanic guy and his english isn't too good. But my friend who translated for me said these parts were the best he has ever seen!
I showed him the LED kit and he was pretty impressed with the contents and the instructions from Mugen. I'm pretty confident that he'll do an excellent job when I'm able to come back and have him install everything for me.
For comparison, he showed me one of the junk parts a customer brought to him for an Audi. It's... rough.
While I was there, I brought the LEDs to my friend at his shop. He tested them with a power probe and they lit up as expected. What I didn't expect was how bright they were. For such a well lit room they show off well. I really want to put them in now but of course I have to get everything painted.
Welp, now I just wait to skedadle off to the Navy.
