41 - 60 of 68 Posts
I know this is late, but I just wanted to "floss" mine.
Did bronze, then hand painted "HONDA" white.
I also have a blue oil cap with a custom carbon fiber center.
I think the two go together nicely.
As well as match the car.
:wiggle:
Here is a close up of mine that I did a while back ago. The second picture shows the similarities/differences between the paint I chose and the stock ssm paint of the car. You can't tell from the picture but the top half of the cover is speckled.
Anyone tried any of the plethora of colors from the model car spray paints from Testors? I'm wondering if it is durable enough for this application....it definitely works with plastics.
Caliper paint will work fine as long as you suff then clean surface before hand as proper paint prep. work.
The intake manifold is plastic as well as the cover so neither get as hot as an engine block or metal intake manifold would. On that note, caliper paint is not a necessity but it is just as functional.
Ok, just wanted to be safe about it. So scuff it with sand paper, clean it off, then paint?
Thanks Goose.
What color are you planning on painting it? I got the Fit manifold and hit it with a couple layers of VHT Anodized Base Silver Color so the yellow I put over it would seem a bit brighter and the black would be easier to mask.
41 - 60 of 68 Posts
