Which aftermarket camber bolts to buy?
12K views 23 replies 10 participants last post by  RedefinedCRZ
good questions. I havent gotten this far yet but I'd like to know also.
As far as I know the ones for the FIT work for the CR-Z also so that means that Eibach has a set. I dont know if anyone is using the Eibach ones though.
the ad for the bolts that hotboxn put up says to replace the top bolt. I assume if youre only running one bolt ber side that you want to replace the top one.
hotboxn, do you have any idea how much camber you can get with one bolt vs two per side?
