1 - 3 of 3 Posts
It's a 6speed manual. I found these parts mentioned by another user:
94109-20000 Washer, Drain Plug (20mm) [fluid fill]
94109-14000 Washer, Drain Plug (14mm) [same size as engine fluid drain plug crush washer]
I'm not sure if that means that the fill and drain plugs needs different washers or it's optional and both size is fine.
UPDATE: I went to a honda parts dealer today. It turned out they are different sizes. Fill plug needs 20mm washer and the drain plug needs 14mm.
1 - 3 of 3 Posts
