8681 - 8700 of 8790 Posts
CR-Z 2012 storm silver
Ordered plugs and valve cover gasket. I am at 166k miles. As far as I know, original plugs and no valve adjustment ever done. I have not done it. I may go after the coolant also since I have no idea when it was changed either.
Sounds like a really good idea, too all of the above. 👍🏻 It will maybe even help you gas economy . Since it has never been done before.
Remember to do a reset and idle learn. When done.
Lots of threads for that and adding electric motors to the rear axle. All is fantasy and thought discussions and not one person has done anything other than the current thread talking about adding batteries and conversion to LI-ION(Converting my Nimh CRZ to Lithium and boosting IMA...). In the long run if you want a 100% electric car there are many off the shelf cars you can buy(Tesla Model 3 $40K, Nissan Leaf $31,600, Mini Cooper $30,750 and others). There are many companies that now exist to convert all kinds of vehicles to 100% electric successfully so there are more supplies available if you decide to do this or have it done. The costs to make a one off from scratch is extreme and makes it something special that won't meet requirements like insurance, inspection, etc.
But if you can do it like @Fediej says go ahead and hack the hell out of your CR-Z and have fun.
Here is a quick search from this forum on the topic of conversion to full electric:
1. Search for the threads pertaining to this subject(it has been brought up b4)
2. If you think you can do it, than do it! But either continue one of those threads that you searched or start your own. Unless you already did the conversion, than that counts for this thread. 😁
May not need the reset and the Idle relearn. Mine has had all fluids replaced ( some multiple times), all air filters replaced yearly along with wiper blades. As I just hit 76K miles I see no reason to change plugs or coils yet. I will wait on that till the Minder tells me. If you do Transmission fluid do not forget the inline filter which is listed as part of the radiator.
Replaced the under hood battery today, yesterday I went to the dealership to see if it was still under warranty but left after waiting two hours for a technician to look at it. As I sat there waiting I listened to the technicians up selling stuff that is not required. The worst person after a used car salesman is a service technician. No offense to anyone here. Just went to my nearest AutoZone this morning and had it replaced.
15 minutes tops!
Reactions: Spdbump
I ran up to Honda and got two gallons of Type 2 coolant. The hardest part about that job was finding the engine drain plug. I think I've got it burped and ready to roll. I'll know tomorrow. I have a doctors appointment about 25 miles away. I'll check the level tomorrow before I leave and top it off if needed.
If you do coolant do not forget the inline filter which is listed as part of the radiator.
What is this coolant filter you speak of and where is it located?
I would have had my 10 MM wrench in the car walk in with battery have them load test walk out with new one install and drive away.
15 minutes tops!
There is an inline filter for the transmission(CVT) not the coolant. I typed the wrong information. This inline filter is on the back of the radiator and is on the line for the transmission cooler which is a separate part but built into the radiator. Mea Culpa I was typing fast and messed up. It is listed as a radiator part.
Back to OEM wheels since winter is arriving in a month. Could possibly deal with crazy rain & snow (maybe). I don’t want to keep driving on my Advan RGII’s since it’s discontinued & 12 years old so anything can happen. Rather keep it in one piece during the winter.
While putting away the wheels.. I found a nail.. Guess this is the reason why I had 11 PSI earlier today on my rear driver side
So far this week, I changed the brake fluid all around. Changed the coolant. Changed the spark plugs with a set of REAL NGK plugs. Set the valve clearance. Cleaned the throttle body and intake. Cleaned the EGR as best as I could. After all of that, it did start up and run after the fact. I only ran it long enough to get the car to back up so I could pull the wheel chocks out. Should be good on maintenance items until the next oil change for a while.
I did similar in The Speed Bump but mine is on the dash below the radio and is slightly different but does same. Information is a good thing!
Added a cabled obd2 display so I can see all the temps and battery voltage. I just like having more information, and the "ambient light" matches perfectly with the rest of the dash!
I have a voltage display in the power outlet thing I got to expand the available connections (2x12V, 2xUSB, 1xUSB-C) so I can run my phone and ham radio stuff in the console. Interesting how the inverter will maintain 13.8V during auto-stop if you have the lights on.
I don't have a need for other full-time gauges but if I want to check something I can always plug in the Bluetooth dongle and fire up Torque on the phone. I suppose one could make that a permanent setup with a surplus Android device.
