21 - 40 of 100 Posts
· IMA Enthusiast
Discussion Starter · #21 ·
A hunch... :unsure:
I'm following a bit of extrapolation and suspicion here but I suspect the HPD IMA tuned 30+kw CR-Z was basically using a hacked HCH2 IMA setup.
I've been studying the workshop manuals of the CR-Z and the HCH2 IMA side and the basic signals all seem to be present in the right places.
The CAN data on IMACAN & FCAN looks very similar so I am suspecting an HCH2 battery/control assembly might actually work in a CR-Z.
The HCH2 was a higher voltage setup and I know from testing the DC-DC can take 220V
(Almost double the Nimh CR-Z 100V and +50% over the Lithium 144V version)
So plenty of potential for pure voltage increase power there.
Also looking at the HCH2 phase and current sensors they might be easily fooled with some resistors to allow higher currents as well. Double whammy.
So I'm going to buy a complete HCH2 IMA assembly and plug it into my Lithium car and see what happens!
If it works I'll then increase the voltage and current.
· IMA Enthusiast
Discussion Starter · #22 ·
Just looked at the HCH2 Inverter on the bench and the U,V,W phase sensors and it does look like they can be fooled with resistors to allow higher currents.
Basically they are a 3 x 5v powered 2.5V = 0A bidirectional sensors.
The output can be manipulated by inserting a 220R resistor in series with the output and then 2 x 1k resistor pull up and down to +5V and GND on the output end.
This basically forces the signal to remain at 2.5V more strongly and reduces the voltage swing by about 30%. So for 10A flowing the inverter sees 7A.
So the inverter effectively only sees about 70% of the flowing current.
Basically it says I want 100A but only sees 70A, so has to open the gates wider to let more power through until it sees the 100A
In order for it to command a detected 100A it has adjust the phase control to allow ~140A (+40%)
If we assume a 200V system then 200V x 140A = 28kw = ~37hp
That's a nice increase and the same % as we currently run in the G1 Insight systems.
Of course we can/will likely start with lower % increases and crank it up in +5% or 10% increments until it falls over or blows up!!
2014 Honda CR-Z EX CVT
HCH2 = Honda Civic Hybrid gen 2?
What is the IC on the sensor board? If it's got a part number maybe i can find a datasheet for it's pinout.
If the IC on the sensor board is a current sensor using a magnetic 'u', then there should already be an external resistor we can change to scale the output.
It will be in parallel across the current output and feedback pins.
I'd suggest we use a digital variable resistor in it's place so we can change the % current reading for all three at once.
Can you share an up close picture of the sensor circuit board?
It might follow the same pinout as other current sensors.
On the ones i've used it's been pins 3 and 4.
I was trying to get a look at the MCM and get the part numbers for the uCs off that if you know what they are already that would be a big help to make the MCMs rewritable since i can see some of them have factory updates from Honda in HDS.
· IMA Enthusiast
Discussion Starter · #28 · (Edited)
The core is split with a little 4 pin hall sensor in the gap. It's marked 9 6G
R8 (330k) and C2 are in parallel and connected to the output to the MCM main pcb.
I agree digital pots would be good.
There are no markings on the main 16 pin IC chip even under the scrapped off goo on top of it :(
The reverse of the pcb is just a big ground plane.
I'm assuming the main IC is some sort of OP amp?
Pin 1 appears to be bottom right in the pic.
The circuit appears to have some temperature compensation going on as well with VR1 & 2...
It will get quite toasty in the working inverter and the sensors could see 100C variation between below freezing and nearly boiling.
Passive circuit component Circuit component Hardware programmer Electronic component Electronic engineering
Gas Metal Auto part Machine Screw
· IMA Enthusiast
Discussion Starter · #29 ·
The 5V powered battery current sensor feeds into the BCM module and has two outputs that both sit at 2.5V when no current is flowing.
I'll have a look at one of those on the bench in due course as all the current sensors have to be in sync or the car will detect an imbalance fault.
So if we fool the phase sensors by -30% then we have to do the same with the battery current sensor.
· IMA Enthusiast
Discussion Starter · #31 ·
The main IC in the HCH2 inverter (marked with green line) is marked 64F7047F40V looks like a RENESAS CPU similar to the attached pdf.
Passive circuit component Circuit component Green Hardware programmer Electronic engineering
There is a write enable line on the main harness connector so it can probably be reprogrammed via the CANBUS and HDS...
The main IC in the HCH2 inverter (marked with green line) is marked 64F7047F40V looks like a RENESAS CPU similar to the attached pdf. View attachment 69805 There is a write enable line on the main harness connector so it can probably be reprogrammed via the CANBUS and HDS...
OK I'll look into this in the morning. It looks like the part number for the hch is 1b100-rmx right. Should be easy to pull apart the factory update and extract a partial rom from it. Hopefully from there I can get the whole dump from the mcu.
· IMA Enthusiast
Discussion Starter · #35 · (Edited)
More cross checking and seeing what is possible today while I wait to acquire an HCH2 IMA setup.
I'm also cycling an old HCH2 pack I had in storage for the testing.
It looks like the HCH2 IMA setup will plug straight into the CR-Z wiring harness with perhaps only a minor pin swap on the HCH2 connector. (y)
If this does work then in a Nimh car it would be an immediate +50% IMA boost compared with the stock 100V pack in the early cars. ;)
So i found some tables, not all of them, because im missing a lot of context in the disassembly because of the lack of the first 0x10000 bytes, as the factory updates only provide the updatable data and not the rom in its entirety.
i only found about 20ish tables, i feel like there should be well over 100 tables even though its only a 256kb rom. If i had one, i would probably be able to dump the whole rom. Is 0x18dA02f1 the address of the HCH?
Also i did find the security handler, and should be able to modify hts to be able to dump/edit these roms.
So if i can get my hands on a willing participant, should be able to dump and rewrite them easily
@da-coder I could send you a phase sensor if you want to play around with it on the bench and see how you can modify (reduce) it's output.
With how simple the circuit is, i don't think i need it in person. I think it's a 3 layer pcb. Could you desolder the IC so i can see the traces underneath it?
It's got to be a quad amp but i can't see where the outputs go.
Is it an open loop or closed loop sensor?
