I currently have the original sprintex size black belt on. No problems or squeaks to date
I'm interested in seeing the results of your Dyno session. The tune you are currently running was a dyno tune on my old 11. It was done by a shop that I have less faith in these days after they did a couple goomba moves on the car. I do my own work on the 16 unless its something major or I'm feeling extremely lazy.Just thought I'd add that I currently have made it to 30.2mpg lifetime average with the Sprintex. I am temporarily using @tikeybun old 2011 dyno tune. I'd like to add that the tune has slight engine knock during stop and go at low rpms for a brief moment, but it really only happens when the car sits at a stop for more than 10 secs usually. I'm taking it to get the tune revised on the 8th by a tuner with a dyno. I'll update results when it is done.
what injectors are you using?Just thought I'd add that I currently have made it to 30.2mpg lifetime average with the Sprintex. I am temporarily using @tikeybun old 2011 dyno tune. I'd like to add that the tune has slight engine knock during stop and go at low rpms for a brief moment, but it really only happens when the car sits at a stop for more than 10 secs usually. I'm taking it to get the tune revised on the 8th by a tuner with a dyno. I'll update results when it is done.
If hes using the same injectors i used its gonna be some 270cc Accord V6 injectors.what injectors are you using?
Yes, it was brand new 270cc Accord V6 injectors. The provided tune was set at 252cc for some reason, and it's going to be interesting to find out what the tuner will say. Of course, he has only ever tuned a supercharged 6MT CR-Z, not a supercharged CVT.If hes using the same injectors i used its gonna be some 270cc Accord V6 injectors.
They made a few goomba moves on the car combined with the fact that they couldnt figure out how to get my pillowballs to work on my BC racing suspension. It only took a few hours at @96firephoenix house on quickjacks to get the pillowballs installed and so far no abnormal noise like the shop claimed they were getting. Nice people that run the shop but they made one too many mistakes on my 11 CVT. They also do not support Ktuner so I wont be able to get tuned by them on the 16 anyways.Yes, it was brand new 270cc Accord V6 injectors. The provided tune was set at 252cc for some reason, and it's going to be interesting to find out what the tuner will say. Of course, he has only ever tuned a supercharged 6MT CR-Z, not a supercharged CVT.
EDIT: Also, how come you lost faith with that shop? Did they mess up something or a tune?
Hondata is supposed to be more widely supported then Ktuner so thats a bit odd that there are not that many tuners in Austin TX that support it.I tried reaching out to a ton of places in Austin about tuners that support Hondata/Ktuner or even just Honda's in general, and it seems like no one does except for one guy in San Antonio, so it's the only option I have as far as tuning is concerned.
I would recommend not throwing on the smaller pulley unless you are prepared to invest in a solid water meth setup. You will heatsoak like crazy if you toss the smaller pulley on as the SC kit is not intercooled. I'd also be concerned about the reliability of the CVT with the smaller pulley. 140 HP is better then the results I got on the tune I gave you. Hopefully you get better MPG on the new tune.Has anyone here ever messed with a smaller pully for the sprintex to get more boost? I was only able to get 135-140 hp max with the pully that came with the sprintex unit. My tuner tried to make the tune more aggressive but kept dropping power at 5500 rpm, the CVT did not like it with my current setup.
The tuner knew what he was doing. He explained a lot of stuff and was able to clean up the provided tune you gave me. He said the knock control really needed some work and looked like if it was half-assed in certain areas but was able to clear it up. I have noticed that the new tune revision seems a lot smoother if that makes any sense.I would recommend not throwing on the smaller pulley unless you are prepared to invest in a solid water meth setup. You will heatsoak like crazy if you toss the smaller pulley on as the SC kit is not intercooled. I'd also be concerned about the reliability of the CVT with the smaller pulley. 140 HP is better then the results I got on the tune I gave you. Hopefully you get better MPG on the new tune.
so 5500 is about the top end of the powerband, and it's also where the IMA stops contributing in a meaningful way. 140 wheel horsepower is really good for a CVT and I wouldn't push it much past that.Has anyone here ever messed with a smaller pully for the sprintex to get more boost? I was only able to get 135-140 hp max with the pully that came with the sprintex unit. My tuner tried to make the tune more aggressive but kept dropping power at 5500 rpm, the CVT did not like it with my current setup.
Don't compare a UK user's dyno stats to a US dyno. The tuners in the UK use a lot of funky maths to assume crank horsepower and call it a calculation.I swear that I remember someone in the past had the same setup as me but was able to somehow bring the max hp to 180-190 with the CVT, I think it was @MartinT . I wonder if he used a smaller pulley.
So, a 1 or 2mm smaller pulley is not worth the risk is what you are saying?so 5500 is about the top end of the powerband, and it's also where the IMA stops contributing in a meaningful way. 140 wheel horsepower is really good for a CVT and I wouldn't push it much past that.
a smaller pulley without a TON of supporting mods will destroy your drivetrain.So, a 1 or 2mm smaller pulley is not worth the risk is what you are saying?
I was always told and/or read somewhere way back in this thread that the green belt was smaller. I think if you look up the dimensions of each you can compare the circumference for exampleAlso, about the serpentine belt, is the Gates K100661HD V-Belt smaller than the Sprintex provided belt? You know, the green belt everyone switches to eventually?
