2461 - 2480 of 2501 Posts
That noise is probably the gears or the twin screws in the blower.
I've got a little film of oil building up around the pulley and belt is starting to squeak, so I think it's time to replace a seal or get a rebuild kit. Still sounds/runs great, but getting tired of wiping the engine bay down and getting oil/grime on my microfiber. :)
Send it to Jon Bond and get the oil consumption kit at the same time... Unless you feel comfy with a diy project...
My garage is in such a mess from doing summer projects, and starting on some other little mods on the 6-Speed, that I need to find a clear space to work, haha! Too many diy's going on right now, so I might just send it to them and report back on the experience. :)
I am looking for Sprintex 60mm idler pulley Part# 140-110055
Is there anyone know other part number to purchase from Gates or other bearing brands?
:unsure:
I think the noise you guys are hearing is the heavier injectors.
I was wondering if your Sprintex is still in the box, or if you've actually installed it yet?
Bought a 2 pk 100 ml syringes to do gear fluid changes on the Sprintex. Now to find a good mini foil pan at the grocery store and I'm ready to do Sprintex fluid changes...
Part 1 of 2 for my Sprintex fluid change kit. It's the smallest baking tin I could get from the grocery store. The second part (syringe) should come in tomorrow. Total was less then about $15. The tin comes with a pack of 5 and a cover for each one.
Part 2 of my Sprintex fluid change kit. The syringe has a long rubber like hose that will make getting fluid out of the 1 qt container easy. I might change out the fluid this weekend when I change out my oil just to see what color the fluid is. I've got tons of fluid to spare. If the fluid looks good then I'll do the next fluid change at the dragon meet 2020.
I suppose it's time for my 2 year Sprintex report & review!
As a recap this is my daily driver and I've had the Sprintex installed & tuned for almost 2.5 years now.
The car sees some sort of boost every time I drive and I'm pleased to report that I've had ZERO issues with this setup!
The only "annoyance" I've had is the leaking dipstick since day 1, I'm sure it can be fixed with a different gasket/o-ring but laziness is prevailing.
The boost appears to push a tiny amount of oil past the threads, at least it forces me to keep an eye on the oil level.
Replaced the belt/plugs a couple months ago, both looked perfectly fine. Fluid add/change is easy, just cut a small funnel tip at an angle so it wedges into the fill port nicely.
Not sure how much clutch life I have left but the stock unit is still holding up fine (158000 km)
Low/mid RPM is where this thing excels at, you can defintely feel the power plateauing after 5K.
Off the line is excellent, I've surprised many cars and get random compliments. I do wish the 6MT gearing was a little better for acceleration, especially 2nd.
Fuel economy difference is negligible using Econ on flat ground but any sort of hill can quickly create boost. Sports mode can cause a 15-30% hit but it's so much fun!
I got ~5.5-6.0L/100km before the Sprintex and now anywhere from ~5.8-8.0L/100km, usually around 6.4.
Overall I'm VERY pleased with the Sprintex ?
I got ~5.5-6.0L/100km before the Sprintx and now anywhere from ~5.8-8.0L/100km, usually around 6.4.
how many km did you have when you installed the sprintex?
Used Sprintex for like 3 years.
2 years with only SMT8L, 1 year SMT8L+HONDATA.
Now SMT8L is dead! I decided to remove this SMT8L, using only Hondata to running my Z.
5th injector was really nice, but I cannot run with SMT8L anymore.. I don't want to spend more bucks on this poor ecu.
no i need standart maps for sprintex + ktune
Standard if they exist is a good starting point but realistically you need a tune on a dynamometer by someone familiar with your supercharger and that tuner(KTune). All engines and cars are slightly different and have different environments and fuel availability.
Perhaps Litz can chime in here but when I had my Sprintex installed I had to have the shop Dyno the car with Hondata to make it run properly. I'm not sure what you mean by standard map. Most all of the supercharger kits for the Z don't come with base maps of any sort and assume the buyer will get a professional Dyno tune. You'll also need larger injectors to get the most out of the kit. I've got Accord V6 injectors (270 cc).
Who told you that? All these postings, you already bought the Sprintex and the Ktuner and you can't use the tuner. I feel bad for you that is a lot of shekels to be out.
Have you found a local tuning technician/shop who is familiar with CR-Zs? If so what tuner do they recommend? My understanding is this is not a plug and play upgrade. To get full benefit it needs tuning by a knowledgeable technician to get as much HP as possible and not blow the engine or transmission.
usa car suppord ktune !!! my car euro ... not support
