1 - 20 of 42 Posts
I know the car is still new and its considered a baby in the aftermarket world.
I have a few gripes about the current offerings regarding sway bars and strut
tower braces. First, all the strut tower braces out there seem to all mount to
places like inner fender braces and sheet metal pieces. Where are the ones that
actually mount to actual strut towers? Secondly, lets talk about those oem front
sway endlinks.....they are pencil thin and will definetly need a major upgrade.
Hopefully somebody steps up. And my biggest gripe yet. The rear "sway" offering
from cusco. Let me explain why. Obviously we all know our car doesnt have a
rear sway bar. However, we do have a huge epic failure called a torsion beam.
This cusco "rear sway bar" as they call it should be called something like a "torsion
reindorcement bracket" since its not a sway bar. But aside from that, it looks like a
frail and flimsy add on to an already crappy torsion beam setup. Not spending $300
on that....
END RANT.....(flame suit on):pP:
What do you folks think?
You probably won't see any chassis bars that mount to the shock tower since there aren't provision for it from the factory. Civic's, RSX's, and other older Honda's typically used a 2-bolt system that would accomidate a very basic shock tower bar. Thats why there were countless offerings from brand name and grey market companies for those models. With the 2nd gen Fit and CR-Z, that option simply isn't there. You wouldn't want to rely on the single shock nut that sticks through the towers, as enough pressure would cause it to break completely.
There is a good solid area to anchor a bar underneath the plastic cowl (the one that surrounds the windshield wipers and closes the gap between the hood and windshield). Here's a picture of that mounting point during the mock-up process that my fabrication guy went through when he built a custom piece for me recently. This bar ties into the anchor points on each end, under the cowl, and then to the front core support. (Disregard the nuts serving as bolt spacers, they were only used during the initial mock-up.)
Under the plastic cowl, just behind the drivers side shock tower
on that....
I think youd be surprised with the RSB. I dont own one yet but theres a huge difference on other (non torsion beam cars) from increasing the stock one even 4mm in diameter. On this car, it would be hard to believe that the RSB makes NO difference. Only an owner can tell you definitively though.
i meant Rear Sway Bar by RSB.
but good to see youve done the front and rear "strut" bars. Did you have to drill holes in the bay for the front strut bar or are the mounting points already drilled out?
No holes need to be drilled, its fully bolt on and the hole exists already -- its actually a pretty cool design -- at first your like this isnt going to do anything but once fully bolted up and tightened down its really snug and the cars chassis/suspension moves if you grab it and wiggle back and forth. Good stuff, Im stoked on mine, keeps the car a bit flatter. :thumbsup:
i'm installing the cusco front/rear sway soon. just go them.
was waiting for some adjustables but doesn't seem like anyone is making?
should help with the body roll for not so much money.
not sure about the front strut brace - since the strut tower are welded to the firewall?
will it make a hguh difference?
not sure about the under chasis braces. are they worth it?
although i like kamispeed/cusco/tanabe 4-point braces and not too expensive.
not sure going the lowering springs or coilovers. will have to wait and see.
later
dan
Discussion Starter · #12 ·
progress made an amazing rear sway bar for the fit and it made a world of difference in the rear end when cornering hard. hopefully they release one for the crz.
edit: and it was only $150 not $300.
exactly my point.....
progress also made an amazingly beefy set of sways for the 8th gen civic.....
and they were like $300-something for both.
cusco makes sways about half the thickness for twice the price.....they are insane
i have and plan on installing the Cusco front and rear sway bars. i come from the VW world and the rear "add-on" sway bars do work on torsion beam rear ends. they add additional stiffness to the rear torsion beam.
regarding the front end stuff, i have contacted all the current mfg's and i have not been statisfied with their offerings.
where's the mount points for the kansai front strut brace?
thought the cusco looked nice - but the mount points are on the fender frame?
thanks for info.
later
dan
the kansai and spoon attaches off on the side of the struts, you can see it in this picture they're like 2 bolts
afterward it is not that noticeable because the plastic housing the windshield wipers and such covers that up
1 - 20 of 42 Posts
