1 - 20 of 53 Posts
So as some know my first CRZ was wrecked. I stripped the car down over a couple of weeks and saved anything I could (which was everything). After months of searching I found a 2011 6MT SSM CRZ with 37,000 miles on the clock, the car was pretty much new and had some small things done to it already. So lets get into it.
Instagram name is: pumpkin_trice
Most parts for this build were purchased through Kamispeed
Handling:
Main wheels: Desmond Regamasters 17x8 +35 square
Backup wheels: Weds TC105X 17x8 +32 square
Buddy Club N+ Spec coilovers paired with Swift springs and rear metric perches
Beatrush Pillowball mounts
Spoon Rigid Collars front
Spoon Rigid Collars rear
Spoon FSB 25mm
(Front) Spoon Monoblock Calipers w/ Stoptech Rotors and Goodridge SS lines
(Rear) Stoptech Rotors, Pads, and Goodridge SS lines
Motul RBF 660 Brake Fluid
Powerflex Urethane Rear LCA Bushings
Backyard Special Urethane Rear Suspension Bushings
Hasport GERR U70A Trans mount
Cusco RSB
Cusco chassis bracing
Cusco front strut bar
Project Kics R40 Iconix lugs
Daily Tires: Michelin Pilot Sports A/S 4 215/45/17
Track Tires: Hankook RS4’s 215/45/17
Engine:
Tuned By: John Vega at Phearable
HKS GT4015 Supercharger kit
HKS Clutch Kit
HKS M40i superfire spark plugs
HKS Fuel upgrade kit
HKS radiator cap
HKS Oil cap
HPD 6 Rib Pulleys
Hondata Flashpro
Tial QRJ BOV
KoyoRadiator
Kansai Service radiator shroud
Kansai Service fresh air panel
Basis Radiator stays
Beatrush Under Panel
Beatrush Sandwich plate
Maxbore Throttle body
Js Racing Header
Js Racing 50RR exhaust
Acuity solid shifter bushings
Hybrid Racing detent springs
Spoon Sports oil drain bolt
Spoon Sports transmission drain bolt
Spoon Sports braided clutch line
MFactory Helical LSD
Honda OEM EGR block off plate
Ninthgenee TPMSD Board
Interior:
Black center console
iJDMtoy Led interior lighting
Light up crz door sills
Lecce D shaped steering wheel
Zoom engineering Monaco Mirror
Zoom engineering drink holder
Battlecraft Shift knob
Hybrid Racing short shifter
CWEST carbon gauge pod
VLS Boost
VLS Oil pressure
VLS Wideband
Exterior:
Rear wiper delete
Modulo front chin spoiler
Modulo side accents
Zest JDM rear diffuser
Honda access vent visors
Debadged rear
Third brake light flasher
Morimoto XB LED Fog lights (OVAL)
Diode Dynamics LED XPR Reverse Lights
LASFIT LED HB3 High Beams
LASFIT LED CANBUS front Switchback turn signals
LASFIT LED CANBUS rear turn signals
JDM Clear Headlights
Paint Correction and Servface 3 year Ceramic Coat
· Premium Member
Please make sure you let First responders know it is a Hybrid if you happen to need their assistance. See my other postings about this topic. It can kill them if they do not know. With the other changes you have made they may not recognize it as a hybrid.
Well......technically already done. There are some small things I would like to do on this one that I will need Item9’s help with
Sent from my iPhone using Tapatalk Pro
· Premium Member
Some small things...left to do here too. Looks like you've got a better set up than the previous one, I'd say that's a win. :)
· Premium Member
Too late already bought the Honda replacement grip . I think the only part on The Lecce wheels that are Honda is the hub where it attaches to car and where switch pods attach. I searched all over the internet and the only choices as I said were Lecce or Honda replacement new or used.
The Lecce is just a reworked OEM wheel, says Honda right on it. There is a company in Chicago that can redo the OEM
Discussion Starter · #14 ·
. Well if you bought a new Honda wheel that means you have a spare. Send it to TAWcustoms and get it turned to a D shaped wheel. Again the Lecce is the same thing, just a reworked OEM wheel.
Look up TAW on insta they do phenomenal work
· Premium Member
Actually Jim I can’t figure out how to edit my thread from a desktop. So I hit reply by accident lol
I see..., but just so you don't go nuts, you can't edit a post anymore after 24 hours, or something like that. It's a feature of the new format. :)
1 - 20 of 53 Posts
