Steering Wheel Spacer to OEM steeringwheel
632 Views 9 Replies 6 Participants Last post by  96firephoenix
Steering Wheel Spacer? Hello, does anybody had some expierience with Steering Wheel Spacers and the OEM steeringwheel? As I'm not so tall, I wanted to get the steeringwheel closer to me for a more comfy seating position. Now I found this part but it's for the S2000 model.
Is it the same support on the CR-Z and on the S2000 model?
Is there a 6cm reserve on the OEM wires for all the steeringwheel funktions?
It looks pretty similar to me but maeby you know better.
1 - 10 of 10 Posts
Just to make sure - you are aware the steering wheel can be adjusted right? There's a handle on the lower end of the steering wheel column that you can pull to free the adjustment mechanism.
  • Helpful
Reactions: 2
THX! I know, but since I've installed my OEM armrest I prefer to have the steeringwheel even more close to me.;-)
Due to the airbag you really don't want it too close. Even if you are wearing the seatbelt the wheel needs to be a minimum distance away from you to avoid injury or worse if it deploys.
Hello NY-Z, THX for your advice. I'm aware of the function of an airbag. In a technical sheet from Germany I saw a notice that min. distance should be 25cm. In my case it will be still 40-45cm with the spacer. I think I'll feel ok with this.
The Part has arrived today. I'll keep you updated if it works fine.
Tool Gas Wood Auto part Machine
Automotive tire Rim Gas Tool Household hardware
I'd be interested in seeing the results. I see they also have a spacer for the EP3 and FK8 on their site in addition to the S2000. Not sure which one is closest to our spline/hub.
Vehicle White Steering part Car Wheel
Rim Audio equipment Gas Steering wheel Steering part
I have these pic's of our OEM steeringwheel and now I hope it fits as the S2000 SW mod I made on my Insight ZE1.
May I ask you where did you buy the armrest? I've been looking for it shipped to EU for a while with no luck...
I'm also interested in your results.
The Part has arrived today. I'll keep you updated if it works fine. View attachment 70840
1 - 10 of 10 Posts
