He is probably talking about the tighter “sportier” feeling of the car when in sport mode. I can tell the steering is tighter for sure, but the whole car does feel different.Suspension is unaffected by the drive mode buttons. S+ can be used in any mode and forces use of all charge to give more boost.
What are you really asking?
I don't know of anyone who had done it--if you're talking about the tighter feel of the steering while in SPORT mode, but I'd like to have that in all modes too. Since it's electronic power steering, it would only--yes, "only"--take finding the right signal and trick it into activating the "sport" steering mode as a full time setting. I'm just not the one who's taken the time to figure it out.Has anyone hacked the CR-Z so that you can have the sport suspension without the performance boost on?
from the other answers here they apparently want the firmer steering feel that you get in sport but not in the other modes in all modes.Has anyone hacked the CR-Z so that you can have the sport suspension without the performance boost on?
Maybe if you had ECU flash tuning software like a Ktuner and took it to someone who could confidently customize you MAP. but know a good dyno tuner will generally command 250 an hour in my findings. I'd say look into some stiffer springs and call it a day. Swift Sports are the most drop and tein will be the most suble, but theres tons on here about all that.
The question was essentially fantasy to start with, so I'll put that out there. although I feel I further clarified what "major re-engineering." could imply
So that feeling is entirely the steering. The suspension is not variable.When I put the car in sport the suspension feels stiffened If you swing the steering back an forth at freeway speeds the car will not sway around as bad. at all speeds the car handles better. Maybe I need new springs. Maybe I need psychological help. But in a world where people are hacking tesla systems I just thought maybe somebody had figured this out.
Sport, Normal, and Econ modes only change the throttle response, IMA input, and steering response.
Sport: very sensitive throttle, tight steering response, and max IMA boost/regen
Normal: moderate everything
Econ: muted throttle input, moderate steering response, and max IMA boost/regen, as well as more auto-stop engagement.
ok that make sense. I still would like the option to have that on All the time
it's just a line of code for how much assistance the motor gives it...Has anybody looked at the power steering to see how the firmness is activated? There has to be a wire that activates it. I would think a relay or other "switch" independent of the ecu and mode switch could be added. It would be a simple on / off we just need to find how to add that "on" signal to the electric steering in the other two modes where it is normally off.
So I've had the steering rack out of my car and in my hands - there is only an electric motor. There's no hydraulic component. The motor is more responsive to input in sport mode, due to coding in one module or another. I'm not sure it's the ECU in particular, but nonetheless it's all computer controlled.I was hoping it was a signal from the mode switch On for firm and off for other two modes. Since it is an electric power steering I thought it might be hydraulic with electrical switch that changes the valving in the power steering. Are you sure it is just a line of code on the ECU? I thought The steering rack itself has to change something for that and I thought it might still be a hydraulic system with electrical control or full electic but still the two modes turned on or off activagted by the Mode switch . I guess I am wrong. Where were you able to find out about the steering and that it has no hydraulics at al and is fully controlled by ECUl? If it is 100% electric controlled by ecu that will make what the OP wanted much more complicated and expensive.Thank you.
I was looking at Rockauto parts for steering and it is wrong then. it listed pressure sensors and other hydraulic parts
