1 - 4 of 4 Posts
Hi folks.
I'm struggling to find front extended/roll centre adjustment balljoints.
Can anyone point me in the right direction
Im assuming you mean Adjustable suspension components? i.e Tie rods , lower control arms? Do you have any photos as to what you are after?
It's an extended ball joint stud (may have to get a whole control arm) (for the CRZ, Others, like my old cressida, can use just a spacer because of how everything bolts up) so the pivot point of the LCA (the actual ball and socket) is lower relative to the tire. Lets you have the ball joint closer to the stock position with lowered suspension so you aren't as far into the camber and toe curve at static height.
i would definitely check out SPC, they have a wide variety of adjustable suspension components especially for hondas.
1 - 4 of 4 Posts
