1 - 7 of 7 Posts
I need to remove the H off my rear hatch. I know it has 2 pins holding it in, does anyone know for sure what holds those pins on the other side ? AND does anyone know how the plastic interior pieces come off on the inside of the hatch so I can get to the back side of the H ?
Thanks,
J
R u talking about the two plastic hubs or the actual H itself? The H has two pins, but unlike the front, the aren't secured into the hatch. They slide into two white plastic hubs. I just replaced my emblems today with red ones. So if you want to see what's under the H I'll have pix posted a little later. But unfortunately since I was replacing not removing I didn't have to worry about the little white hubs.
-Hoi
-Hoi
I need to actual take the H off the Back but, I need to be able to remove and replace. So what did you replace yours with ? Did you just pull off the old H ?
I was thinking I would have to take off the interior panels of the rear hatch to be able to take off the H.
Thanks,
J
No back was easy. Just cut the top adhesive with dental floss and it comes right out. I replaced mine with a red and silver Honda emblem.
The new emblem covers the entire space so I didn't have to worry about the little hubs that are left behind. So it really depends on what you are replacing it with. Should have the pix posted in DIY in a little bit.
-Hoi
-Hoi
-Hoi
-Hoi
Awesome thanks
-Hoi
-Hoi
I was planning to put the original H back on. Is it possible to put the original H back on if I add my own double side tape like the factory uses ?
J
1 - 7 of 7 Posts
