1 - 20 of 20 Posts
i ordered "genuine" honda touch up paint online for my PWP. every other car i've owned my touch-up has come in one applicator. the stuff i got for the CR-Z came in two tubes, a base coat and a top coat. the base coat is pure white and the top coat is a very light milky color with a shimmer. is this correct or should i be pissed?
Prolly sounds right. I always go with genuine honda touch up paint. The top coat is probably the metal flake? it's in two tubes probably because of the pearl in it is seperate. If it was a flat color like taffeta white or milano red it would be one. I just assume its two tubes for the base white and then the pearl white. Hopefully that doesnt get too complicated. It's like..how much of each should i put ya know? *lol*
I've never encountered it. The PMM Accord and LL Mustang both had metal flakes as well, but neither were in separate tubes, and they were both genuine as well.
Hrmm..yea that does make it strange. Maybe do a google search or ask the delearship? I hate asking them for anything, but sometimes you gotta. Or a local body shop?? Unless someone on here can answer it.
· Capt'n Jack
Discussion Starter · #8 ·
Did it (touch up paint) come with instructions? I just did a quick google and everyone is advertising a one applicator with brush.
Example: Honda Touch-Up Paint: Pen (CRZ) - Bernardi Honda Parts and Accessories
But maybe what you have is a more quality product or for a different application?
R/Scott
Interesting. Switch the selection to PWP. It increases in price, and the part number looks more like two parts. I suppose that PWP is a two coat touch up. I've never seen this before.
Also, I'll have to check my receipt,but I think I got it from Bernardi.
Edit: I got it on ebay from the seller "yourhondaparts". It wasn't Bernardi, but it was another dealership, I forget who though. Also, I looked in his store, and he has every CR-Z part collegehillshonda has, but even cheaper. He did however bump up the pricing on the touch-up paint. I got mine for $8 shipped, it's now $15 shipped.
Discussion Starter · #9 ·
another google search turned up this:
Genuine Honda Touch-Up Paint Premium White Pearl Color Code NH624P
Product Features:
Paint sprayers make touchup easy! Save 50% off a Preval Sprayer (when you buy two or more Honda 1/2 oz. tubes).
Simply enter coupon code "ph908" at checkout!!
Touch up paint from Honda
Honda Premium White Pearl Color Code NH624P
Hinders rust and erosion
Don't forget your color keyed Door Edge Guards, Fender Trim & more.
Renews your exterior
2 Part Kit includes Base Coat and Top Coat
1/2oz. bottle with applicator
Edit again: some additional googling turned up more stuff. You can get it as a one coat, two coat, or three coat system. The one coat appears to be for PWP Acura's, the two coat is genuine Honda, and the three coat (base, mid, top) is an aftermarket version.
:staffmeeting:I would like to see a touch up thread showing how to fix chips with the touch up paint and how to get it to look like it never happened, im sure if you use a touch up brush and lightly sand the overage down to the paint level to get it looking perfect. but dont know process and grits and products.......Mods hook it up.:staffmeeting:
Discussion Starter · #11 ·
i've done a lot of touch ups before. mine never came out perfect, but close to. close enough that the dealer never notices a thing when i trade my car in. if you have a scratch, use the pen attachment and fill in that way. if you have a chip, apply the paint in one direction. try to get it to really fill the hole, be generous with the paint, but don't go over the edges of the hole. once the paint dries it will shrink which is why i say to use more than enough to fill the hole. after it is dry, wet sand it VERY gently with a VERY fine grit paper, and try not to sand anything but the chip and the very edges, no need to sand good factory paint.
What grit will be best to use, after could i wet sand with a finer grit to "blend" with original paint, should i clear coat before the wet sand, lil more details on proceedure please.
Discussion Starter · #13 ·
i forget the grits. for some reason 1800 to 2000 is coming to mind, like REALLY fine. i've never had them come out perfect though, just good enough that you can't see it unless you get close up to it. i wouldn't use anything but the touch up paint. i believe they are intended to be all of the coats you need.
While you wait.......
Paints4u Online Car Repair Videos
I've used this Quixx Paint and Scratch Repair after letting the touch up paint dry for about 2 days and turned out REALLY good.
A buddy of mines showed me this when he observed a bit of touch up paint I used on my rear bumper and lower passenger front door. Before if you looked hard you could clearly tell, now you gotta get real close up to tell. :beer:
1 - 20 of 20 Posts
