1 - 7 of 7 Posts
Dear beloved CR-Z crowd,
I am looking for spare parts for a right hand drive CR-Z from 2011.
More specifically a glove box, as the latch is broken.
Which websites in the UK or Japan are worth checking out?
Aftermarket parts are also welcome.
Warm regards from Aruba,
Ayeris
· Premium Member
That latch has been a problem mentioned here before. You have to replace the whole glove box. One member used a latch from a boat shop to replace it. There is no aftermarket replacement. Go read the other threads on this issue. Since right hand drive you are going to have to find the part number for there. I am in US and all the sites I know are for Left hand drive. I am not sure if the glove box is the same for either side. Maybe one of the other members can look up the right part number for your need?
All options were covered in Glovebox latch broken - solution to open
Web search the part number it is above (77500-SZT-E01ZA) or talk to a local dealer. Even check Amazon I have had luck getting some of the parts I needed that way.
As noted above AFAIK (In The US) there was a lighter gray and a darker gray there was no black.
Thank you. I was lucky. Honda has two in stock. Now only one. Tempted to buy the 2nd one also.
1 - 7 of 7 Posts
