O2 sensors and CATS have a finite life and are expensive consumable items.
The P0420 code is flagged/signaled by the post CAT O2 sensor. So we have a few possible scenarios.
1) The pre CAT primary O2 sensor or wiring is bad/old, causing fluctuations being detected by the post cat sensor.
(This may also cause lumpy running or other fairly obvious issues/codes)
2) The post CAT sensor or wiring is bad/old, erroneously flagging up a bad CAT problem.
(Again this may also cause other codes, but not always.)
3) The CAT is actually bad/blocked and the code is correct.
In the past on the Insight I have used post cat O2 sensor spacers to move the secondary sensor slightly out of the gas flow which smoothes out fluctuations.
(It's a handy workaround for scenario 3 and possibly 2 if the sensor is just old) Cleaning/replacing the CAT etc are of course also options for scenario 3.
Attached is the advanced diagnostic P0420 pdf.
Although it doesn't help that much it's interesting reading.
