T1R offers CNC forged aluminum twinblock brake calipers with staggered pistons (38.1/41.3mm) to improve initial, brake modulation and hard braking at all speeds. The caliper weighs 2.43kg approx. 5.35 lbs. Compatible with stock ABS system.
Heat treated steel angle slotted rotors (332mmx25.5mm) with duraluminum hub (floating disc design) are used for excellent heat dissipation and extreme durability while keeping weight down as much as possible. Special street compound (low dust) brake pads are quipped to serve performance from street to track.** Requires 17" wheels to fit**
Pm For Pricing!!
