You can always change it early. If the car has the maintenance minder, some selling dealers just reset it and don't actually change the oil. I have advocated for years that all new owners should change all fluids, filters and wiper blades to get a baseline for the vehicle. Then follow minder or mileage. I recommend the brake fluid be changed every 2 years as it accumulates water. I also advocate load testing or replacing the under hood battery and replacing tires if they are more than 5 years old, no matter the apparent condition.
You can change by mileage, minder or time. With pandemic, I change it annually (0W20 semi or full synthetic). Prior to the pandemic, I changed by the minder when it reached less than 10% or by time. It is no longer required to change every 3K miles. Oil changes are a hotly debated topic here. Oil change is still cheaper than an engine. I have found the maintenance minder prompts for an oil change about every 10K miles. But should be changed at least annually. The 2 air filters are very easy to change yourself, same with wiper blades. I order from
Amazon.com: Online Shopping for Electronics, Apparel, Computers, Books, DVDs & more or
RockAuto for those.
Presume they just reset it and changed nothing, do the maintenance indicated by the B123 also I presume the Service history book is missing or was not filled out. It is very easy from the MID (Multi Information Display) to reset the maintenance minder.
If you have a CVT, there is a filter that is listed as a radiator part located on the back of the radiator. That should also be replaced when transmission fluid is.
If any of the books are missing from the glove compartment, or you want a new service history book, you can order those here
Honda CR-Z
if you have a 2011-12, you can order the factory service manual here
Honda CR-Z 2012 Shop/Service Information
If owner's manual is missing, you can access it online for free here
Honda Owners Site | Tips, Tools & Benefits for Honda Owners
