1 - 7 of 7 Posts
Hi, I just bought a 2011 CR-Z of the fog lens is severely cracked and the bulb is broken. The bulb is easy to find, but I cannot find a single lens anywhere (I'm in Canada). Does anyone know where I could find one? Thanks in advance!
If you need the whole unit here are the part numbers for 2011 from Hondapartsnow.com
Right 33901-SZT-A01 $237.48
Left 33951-SZT-A01 $237.48
But you may find them less expensive from a civic or other sources.
As far as I know, these shapes are more or less standard. your model uses the ovals. You can get nicer LED fatermarket fogs, or OEM style fogs in places like eBay or AliExpress
I used these. Just swapped the bracket and it’s plug and play. Fixed both fog lights for under $35
I had the same problem on my 14 (cracked lens but nothing else wrong). It is a different style unit from the 11 but im sure its the same process. Ended up buying a new foglight unit online (or if you need it asap you can go to a dealer to see if they have it in stock) for an easy swap. Came with a new bulb too. Good luck.
1 - 7 of 7 Posts
