In Different Domestic markets, the menus and options in the MID were different. Another member could not get to the settings screen. For his market, the parking brake had to be on and the settings menu looked like an icon of a piece of paper. Before changing your cluster, get a hold of the owner's manual for the market it was built for, or turn on the parking brake and go through every menu and every option. That member was looking for how to set the clock that shows up in the MID when the OEM radio is replaced with an aftermarket market one.
Here is that thread. He also could not find the customize options menu. It was not a failure as the other member mentioned, it just was his vehicle was from a different market, and he did not have an owner's manual. He was able to find the menu.
So mine has an aftermarket head unit, so it's showing the time on the MID. It doesn't show the correct time and I have no idea how to set it. I've read some threads here that say I need to scroll to customize settings. But there's one problem: mine doesn't have that. When I scroll through the...
www.crzforum.com
You seem to have a similar issue with the menus and finding the settings. It is IMO is not a failure, as the other member in this thread has mentioned now 2 times. It is a lack of understanding of the correct sequence of inputs to access the functions all CR-Zs have some variation of.
As I told him, there has to be an options or settings menu for mundane things like resetting the trip odometer. It has to be there. It just might not be labeled the same as a US domestic market car is. Those MID menus and available options change a lot between years and markets. An example is not every market has the maintenance minder. Some markets have a speed alert, etc.
You need the owner's manual for the correct market to decode what the light means and how to get to the settings menu, which all CR-Zs have some version of. Not all things are failures, some are just different depending on year and market the vehicle was built for. You probably have the functions, you just need to know how to access them. The link above the guy kept insisting he did not, but once he put on the parking brake and looked at every menu and option he found it. The odd thing is the owner's manual does not mention that magical clock that shows up when you remove the OEM radio!
For US cars, we can access the owner's manual here
Honda Owners Site | Tips, Tools & Benefits for Honda Owners I believe most markets have a similar free page to download and read the owner's manual. If you do not have a correct owner's manual for your car, talk to a Honda representative about obtaining a printed one, it has lots of very useful information you need to have.
In summary, do more research and don't jump to conclusions.
Hello,
Recently I bought a CR-Z and didn't really know much about them. When I purchased it it already had a orange info light. I did a quick search but nothing really popped up and I didn't think anything of it. But now I'm realising I do not have all functions the MID should have, I can't see my MPG's or customize the settings. Also can't find/view the maintenance screen.
See the images below, hopefully someone has experience with this.
