1 - 2 of 2 Posts
Pre-Order Hondata FlashPro Today!
Why choose FlashPro?
In the past Hondata has created the standard for tuning Hondas, and this is no different today with the FlashPro system. FlashPro allows your car to be tuned quickly and easily without modifying the stock computer or connections. Simply plug the FlashPro into your OBD2 service port, tune the car, and flash the new information to the factory computer. The FlashPro system is virtually undetectable by the dealer and will not hinder your OBD2 testing results.
What is Evans Tuning’s deal on FlashPro?
Evans Tuning provides a bit more than the typical shop selling FlashPro. Here are a few things you get from us:
  • As an authorized Hondata dealer, the manufacturer's warranty is valid when you purchase through Evans Tuning!
  • Free Overnight Shipping.
  • Your choice of up to $100 off tuning @ Evans Tuning or $50 etGift Certificate to be used in our online store.
  • Unlimited FlashPro technical support.
Pre-order FlashPro. (Ships December 2011)
FlashPro is slated for a December 2011 release. Be the first to get the only tuning solution for your CR-Z! Click here to place your order today.
What comes in the FlashPro box?
FlashPro includes everything you need to get going immediately:
  • 1 FlashPro programmer (the actual unit itself)
  • 1 FlashPro software CD
  • 1 USB cable
  • 1 Quickstart Manual
Why do I need a FlashPro?
FlashPro enables your CR-Z to be tuned even more optimally for power, reliability, and fuel economy than it was with the factory driving maps. We are able to do this by completely customizing new driving maps on the engine computer to specifically fit the needs of the engine in your particular CR-Z. This can be done traditionally on a dyno and in the future will be available through eTuning.
What is Tuning?
Tuning (also referred to as engine tuning, Dyno Tuning, or eTuning) is the process used to alter the stock computer, and ultimately, how a car runs. This is typically done after adjustments to the car’s stock configuration have been made. For example, if a turbo kit was installed on a car that was not equipped with one from the factory, tuning would be necessary to make it run properly and safely again. Click here to learn more about tuning.
What is eTuning?
Evans Tuning has helped to pioneer a new type of tuning process called eTuning. With most newer Hondas we are able to tune the car via email, which allows us to serve a wider base of customers. Click here for more details on eTuning.
When will eTuning be available for the CR-Z?
We hope to be able to offer CR-Z tuning shortly after the release of FlashPro. However, we will first be focusing on perfecting the CR-Z tuning process on our in house dyno.
About Evans Tuning.
Evans Tuning is a premier EFI Tuning shop located in Mt. Bethel, Pennsylvania. We are dedicated to providing the highest quality customer service, the best parts, and the best tuning available in the automotive industry. Visit us at Evans Tuning - Dyno Tuning, eTuning, Aftermarket Parts, Fabricaton
Discussion Starter #2
FlashPro for CR-Z is scheduled for an early December release from Hondata! Make sure you are on our list of pre-orders today to be one of the first with the best tuning solution for your car.
1 - 2 of 2 Posts
