1 - 13 of 13 Posts
Hello Forum,
Just received the Lamin-X Fog light protection film (model #H132) for the CR-Z. Upon trying to install it, noticed that it doesn't fit. It is way big. Almost off by 1/2" on both sides top to bottom. I called Lamin-X and they told me that there might have been a mistake on their end. They are going to remeasure and redo the template for future films. They said it might take couple weeks to redo.
So if you are in the market for your fog light protection film. I would wait at least until middle of March before ordering them.
On another note, the folks over at Lamin-X were very friendly and polite (sending me the correct one when it is available).
Discussion Starter · #2 ·
Just received the recut protection film from the folks at Lamin-X.
As you can see from the picture below. The one on the right is the new (correct) template cut.
Here's another photo with the new film temporarily covering the Fog light.
Hope this helps.
FYI, I ordered the clear 20mil film.
mine were HUGE also. But i never used them. LaminX yellow wasnt yellow.
You should let them know. They will replace them for you. Personally I would just get the clear one for protection and if you want yellow lights, replace the bulbs with yellow bulbs.
I ordered mine (40mm clear) the first part of April and they were fine when I got them.
They fixed them mid march. I must have been the first one to order them back in January.
From the road
do you have to remove the fogs in order to place these? my yellows are waiting! my LED bulbs are waiting too.. i haven't had the gall to go and try and do them myself. any step by step help would be appreciated.
Discussion Starter · #8 ·
No, you don't have to remove the fog lamp. It is pretty easy, just peel and apply evenly as best you can. They have an installation video if that helps.
YouTube - Lamin-x Fog Light Cover DIY Installation
Discussion Starter · #10 ·
Where did you get them from?
You can buy the film from Lamin-X.com. The video was on their site. I also talked to them awhile back when I first bought it because of the size issue with the first batch.
Discussion Starter · #12 ·
Thanks, so I assume then the size situation has been worked out...
Um, Yes. In an earlier post, I did a small write up about them including photos.
1 - 13 of 13 Posts
