Orange pad for cutting deeper scratches + polishing compound = First pass over(s)
White pad + finer cutting compound and or polish = second pass over(s)
Basically, you start with the orang + higher cut, then go up to the white + finer cut, then polish with white, and or black if you have a black one.
The orange is the 'cutting' one though. Though.. it really doesn't cut much. That all depends on the polish.
You will be fine though, just give it a go. Just make sure you dont stand in one place at a time with the buffer. ALWAYS keep it moving and you will be good.
Also, make sure to put the compound on the buffer, then spread it around a bit with the buffer on the car, and make sure the machine is touching the car when you start it up so you don't fling that crap everywhere. Compound SUCKS to remove off stuff!!
