Drove 4 hours to Savannah to pick up as set of Sparco Pro Corsas which are 17x7.5 +45. First wheels I've ever bought, so I will probably baby them. Not that it's a bad thing.
Put one on mine, too. Will you be putting a rear bar on also?
Here's the DIY I followed (sort of) for my install, but I swayed a little off course of Canadian's instructions, and added a bit to the end of his post (it was too tight a fit for me to get the old one out and new one in without cursing.):grin2: http://www.crzforum.com/forum/do-yourself-articles/33818-diy-front-sway-bar-r-r.html
Got around to updating my door speakers from these little things. I don't have any pictures of the Kenwoods I installed.
Installed the Spoon Sports sway bar over the weekend. Thanks to Kamispeed to getting this thing shipped pronto. The install was fairly straight forward and having a breaker bar made all the difference.
@jasonw what size rear wheel spacers are you running for that flush look sir? I ordered the exact same wheels, do you have any rubbing issues at all? and how much did you lower from stock height, I am planning on just lowering 1.25" all the way around from stock height....
I'm currently running 10 mil but I feel I could go up to 15 mil spacers without rubbing. Also, I'm dropped 2" all the way around with some room to go, but that's only because I did some trimming. You may or may not have to.
so you are not rubbing on that 2" drop on the sparcos? If you feel like 10mm is cool, I might just stick with 10mm, I live in Michigan and the roads are **** here. Did you have to get longer studs?
I bought the 2 way speakers, here. I had to drill holes to mount them and had to use spacers for all four too. I like the way they sound, I can pick up on strumming on acoustic guitars when I couldn't before. There are much better speakers out there, but these fit my needs and budget.
