So I haven’t had this car for too long and I checked the dip stick on a cold start. Maybe just 3min of running time at idle. Can someone verify if the oil is low and if so what type should I get from O’reilly, autozone or advance?
Yep. And to add to that, you need to drive around and get the trans up to operating temperature before checking the level. It should be at the HOT mark if you check it within a few minutes after shutting off a warm system. Also, do a double check in the morning, when it's cold, and the level will be at the COLD mark.Might as well change it.
Got to Honda, get three bottles of CVT fluid. Drain it and then fill it will all three quarts of CVT fluid. It will be right on the money.
