1 - 5 of 5 Posts
Honda CR-Z Pricing
- 2011 Honda CR-Z 6 Manual Transmission - $23,490
- 2011 Honda CR-Z CVT Transmisison - $24,290
Honda CR-Z Colours
- Storm Silver Metallic Exterior with Titanium Fabric Interior
- North Shore Blue Metallic Exterior with Titanium Fabric Interior
- Premium White Pearl Exterior with Titanium Fabric Interior
Honda CR-Z Specifications
ENGINE
1.5-litre, 16-valve, SOHC, i-VTEC® 4-cylinder with Integrated Motor Assist IMA®
Horsepower @ rpm* - 122 @ 6000
Torque (lb.-ft. @ rpm)* – manual transmission (MT) - 128 @ 1000–1500
Torque (lb.-ft. @ rpm)* – continuously variable transmission (CVT) - 123 @ 1000–1500
Displacement (cc) - 1497
Emissions rating - Tier 2 Bin 2
Bore and stroke (mm) - 73 x 89
Compression ratio - 10.4:1
Ecological Drive Assist System™ (Eco Assist™)
Recommended fuel - Regular
*Horsepower and torque calculations reflect SAE net Rev. 08/04, SAE J1349 procedures.
DRIVETRAIN
Close-ratio 6-speed manual transmission (MT) - Standard
Continuously variable transmission (CVT) - Available
Drive-by-Wire Throttle System™ - Standard
Front-wheel drive - Standard
Steering wheel-mounted paddle shifters - Available
Three-mode drive system (Sport, Normal, Econ) - Standard
CHASSIS
16" aluminum-alloy wheels - Standard
All-season tires - P195/55 R16
Electric power-assisted rack-and-pinion steering (EPS) - Standard
Front and rear stabilizer bars - Standard
MacPherson strut front suspension - Standard
Power-assisted, rear disc brakes - Standard
Power-assisted, ventilated front disc brakes - Standard
Torsion-beam rear suspension - Standard
SAFETY
3-point seat belts with front pretensioners - Standard
4-wheel Anti-lock Braking System (ABS) with Electronic Brake Distribution (EBD) and Brake Assist - Standard
Active front seat head restraints - Standard
Advanced Compatibility EngineeringTM (ACETM) body structure - Standard
Creep-aid system - CVT only
Dual-stage, dual-threshold front airbags (SRS) - Standard
Front side airbags with passenger-side Occupant Position Detection System (OPDS) - Standard
Hill Start Assist - MT only
Immobilizer Theft-Deterrent System - Standard
Security system - Standard
Side curtain airbags - Standard
Vehicle Stability Assist (VSA®) with Traction Control - Standard
EXTERIOR
Body-coloured door handles - Standard
Body-coloured heated folding power side mirrors with integrated turn indicators - Standard
Front splash guards - Standard
High-Intensity Discharge (HID) headlights - Standard
Light-emitting diode (LED) taillamps - Standard
Rear window defroster - Standard
Rear window wiper - Standard
COMFORT & CONVENIENCE
Accessory socket - Standard
Automatic climate control with air-filtration system - Standard
Cargo area cover - Standard
Cargo area light - Standard
Door-pocket storage bins - Standard
Driver's and front passenger's illuminated vanity mirrors - Standard
Eco Assist™ coaching display - Standard
Exterior temperature indicator - Standard
Front beverage holders - Standard
Fuel consumption display - Standard
Glove-compartment light - Standard
HandsFreeLink™-bilingual Bluetooth® wireless mobile phone interface - Standard
IMA® battery state of charge indicator - Standard
IMA® charge/discharge indicator - Standard
Maintenance Minder system - Standard
Map lights - Standard
Power windows with auto-up/down driver's window - Standard
Programmable automatic power door locks entry system - Standard
Seat-belt warning chime - Standard
Spare tire - Standard
Steering wheel-mounted cruise control - Standard
Tachometer - Standard
Tilt and telescoping steering column - Standard
Variable intermittent windshield wipers - Standard
ENTERTAINMENT
360-watt AM/FM/CD Premium audio system with 6-disc in-dash CD changer, MP3/Windows Media® Audio playback capability and 7 speakers including subwoofer - Standard
MP3/auxiliary input jack - Standard
Radio Data System (RDS) - Standard
Roof-mounted antenna - Standard
Speed-sensitive Volume Control (SVC) - Standard
Steering wheel-mounted audio controls - Standard
USB device connector - Standard
SEATING & TRIM
Driver's seat with manual height adjustment - Standard
Floor mats - Standard
Folding cargo tray behind front seats - Standard
DIMENSIONS
Cargo volume (L) - 711
Curb Weight 6MT/CVT(Kg) - 1205/1229
Fuel tank capacity (L) - 40
Gross Vehicle Weight Rating (Kg) - 1435
Ground clearance (mm) - 143
Headroom – front (mm) - 938
Height (mm) - 1394
Hip room (mm) - 1308
Legroom (mm) - 1085
Length (mm) - 4079
Passenger volume (L) - 1390
Shoulder room (mm) - 1367
Track – front/rear (mm) - 1515/1500
Wheelbase (mm) - 2435
Width (mm) - 1740
FUEL ECONOMY† (L/100KM)
Manual transmission (City/Hwy/Combined) - 6.5/5.3/6.0
Continuously variable transmission (City/Hwy/Combined) - 5.6/5.0/5.3
†Fuel consumption for comparison purposes only and may vary with usage and accessories. See dealer for latest EnerGuide results published by Natural Resources Canada (when available).
Honda CR-Z Accessories
- CR-Z Style Package: Front, side, rear and wing spoilers - $2372.76
- Essentials Package: Floor mats, armrest, upgraded rear view mirror - $1194.58
1 - 5 of 5 Posts
