1 - 4 of 4 Posts
I own Honda CR-Z 2011 EX- Few days ago, my IMI (yellow) light indicator showed on screen, then the battery red light indicator showed, then the SBS light indicator , then the radio turned off then the AC turned off, and then the steering wheel yellow indicator light turned on and i couldnt move the steering wheel > then i turned off the ignition and couldnt turn in on again.
The mehanic looked at it, replaced a fuse that was broken, left me one spare if it will happen again.
It did happen and i changed it and I could turn the car on. but then it happened again, so i called the garage and now they are saying that after the check the "Motor, Cooling Fan ", catalog: 1J816RMX003 , needs to be replace > it wll cost approx 660$ include work..
what can i do? sombody had this problem before?
* if i can get the part, they will charge me 165$ for the work..
This is a common problem and has been discussed a lot before, did you do some searches on here?
I get lots of search results.. ;)
You basically need a new/replacement fan or fix the old one.
A fan PCB board from an HCH2 Civic, Jazz Hybrid and Insight G2 Hybrid will probably all be suitable.
P1448 Bad IPU IMA Fan.... Can it be fixed?
Yes, this issue has been discussed before with detailed instructions on how to replace it yourself. The part is discontinued but has been replaced by a new part number or you can follow what @PeterPerkins suggested above. It is a difficult part to find but easy to replace if you can acquire one.
A quick search will show dozens of threads on this issue. In future please search first and add to an already existing thread as it takes a lot of time to find related threads and combine them.
1 - 4 of 4 Posts
