1 - 9 of 9 Posts
Currently using HIDs and DLRs in my Uk spec CRZ. However, the high beam is using a halogen bulb. The halogen doesn't look nice with the rest of the white lights. Can I replace the halogen high beam bulb for an LED bulb? I don't use high beam often, only to flash someone.
Yes you can. Diode dynamics a sponsor here sells them or use their site to figure out the bulb type. Chart in owners manual uses designations I could not find when I was looking. Depending on how old HIDs are you may want to replace as they dim over time.
worth noting that the LED replacement high beams only will work correctly if you have the LED strip of running lights... You'll get a DRL fault code on the dash or else it will flicker if you put an LED bulb in the socket.
I presumed since he had HIDs he had an EX with the LED strips but good point!:)(y)
Discussion Starter #5
I have the UK version, its called GT model. it has DLR strip which is always on, HID low beam lamps and a separate halogen one for the High beams.
Just like US Version with HIDs ours is called EX ( at least in 2013) HID low beams , Halogen High beams and LED strips for DRLs. I believe the Halogens are used for DRL only in vehicles with Halogen Low beams and no HIDs. In US Base models.
the Halogen high beams are used at 6 VDC as the DRL on the 11-12 USDM EX with HID and 12 VDC as the high beam, as well as the USDM 13-16 base/LX
So I guess no LEDs for me since I have a 2011 EX with no LED strip for DRL :cry:
well.... It can work. You can use an anti-flicker module to get them to work as a low-power DRL and a high-beam. But some LED bulbs have a minimum activation voltage that the CRZ's DRL module will not trigger - leaving you with no light output and an error message on the MID.
1 - 9 of 9 Posts
