Load test Under hood battery but it is an odd presentation . If you have Battery charger or a Jump starter attach to battery to see if you can then get lever into gear and it is Brake not break. Sounds like an odd presentation of a low under hood battery.
One other thing to check and it is a long shot is check the fuses for the brakes and your neutral safety switch or brake switch may have failed. Can you move the lever but it does not do anything or you cannot move it? Does the car start? If car does not start in Park try neutral.
Since it affects putting car in gear or car moving it will need a trip to a shop on a flat bed.
