1 - 2 of 2 Posts
Well I can tell you that normally, normal ware and tare items are not covered. This generally includes oil changes, tans fluid changes, brake pads / rotors, wiper blades (some times cover 1st set), clutch disks or flywheels, tires, etc.
However if another component fails causing abnormal ware, ie you have a warped rotor because your caliper stuck, they will replace everything associated with it. Or your throw out bearing goes bad, burning up your clutch, they will cover your clutch.
Also, Honda and non Honda aftermarket parts do not go well together. They have made it very clear that they will not cover your car if some other companies product causes a Honda part to fail.
For further details, contact your local Honda Service Department. LOL
1 - 2 of 2 Posts
