I would like to see the horsepower up around 150 personally
Seem like pretty good numbers for early estimates.It (CRZ) has a hybrid drivetrain featuring a 117-horsepower, 1.5-liter gasoline engine and a 13-horsepower electric motor if the company employs the off-the-shelf hardware already serving in the Fit and Insight models.
The real reason to hope the CR-Z will be fun to drive while it wrings the maximum miles from each gallon of gas is the torque of the combined drivetrains. The electric motor contributes a significant 123 pound-feet of torque to the gas motor’s comparatively paltry 106 pound-feet maximum.
We cannot add these numbers together to learn the system’s peak torque because the gas and electric motors develop their power at different RPM, but we do get a picture of how the electric motor’s torque will fortify the peaky gas motor, which makes its torque at 4,800 RPM.
So if Honda put a bigger electric motor, but stayed with the same gas motor - does this mean more torque then?The electric motor contributes a significant 123 pound-feet of torque to the gas motor’s comparatively paltry 106 pound-feet maximum.
I think with Hondata, Intake, Headers, Exhaust we should easily see a 20-30whp gain. I think a 142-152hp (121-131whp) CR-Z would be quite nice as a daily driver and without much sacrifice with mpg (Maybe even an increase).Would be nice to see someone fitting in a full system exhaust.. I wonder how much gains would be made if done properly.
I too, personally would want extra power without going down turbo/supercharger route as it'll make "Hybrid" meaningless.. but maybe in the future, I'll hold myself content for now! :blush:
My numbers were a little higher, but very little parasitic loss as best I can tell.I dyno'd mine at my friends shop, Equilibrium Tuning, Inc.. Stock they are said to have 122hp and 128tq. The dyno'd showed it puts 101whp and 111wtq, which is not bad since there isn't much loss. The way I look at it is this, it’s the CRX with a B18B 93-98 (LS) Long Block (145Hp 127Trq JDM) but weights 400-500lbs more and lacks a tad more in the top end. I think the CR-Z has potential with a turbo but defeats the purpose of a hybrid. I don't know much about the electric batteries or the electric motors.
If someone wanted to make this car a rocket like a CRX w/ B18C1, I would say Turbo and upgrade the batteries (if possible). Supercharger would be a waste in my opinion since you get the instant torque from the batteries. The weak point of the car is the top end, which the turbo would make up for. Maybe find a way to reduce the compression ratio and maybe some titanium valves and retailers, built heads, etc. That should allow more boost and a higher redline. Once again, it defeats the purpose of the hybrid.
One thing I have to say about the hybrid, 42mpg my @$$. Econ mode feels like a slug and it dangerous trying to get on the freeway while people are cruising at 80mph. Seems you have to keep it in Normal or Sport mode to compete with other drivers. I average 33mpg which still isn’t bad compared to most cars on the road. I believe a turbo would help with fuel economy if you can keep your foot out of it?
EDIT: Keep in mind his shop is running a version of a Mustang Dyno which projects numbers close to actual real world numbers.
Yeah I saw yours earlier, thats why I edited my posting about being on a Mustang Dyno. I hear Dynojets are a little generous on the numbers. A Mustang from what I have read shows close to real world and about 15-25% less hp than a Dynojet (depending on the calibration). This is the exact reason I hate Dyno's since you can calibrate them and you can have it say you have 1000hp when realistically you have 400hp. Best way to get real numbers is to road tune.My numbers were a little higher, but very little parasitic loss as best I can tell.
WHP: 110-112 @ 6000 RPM
WTQ: 119-126 @ Idle
That's less torque than what the car has currently. You'd have to rev it up to 7500 rpm to attain that much hp with only 105 ft lbs.150 hp/105 torque
