1 - 6 of 6 Posts
Hi all,
I own a Honda 2013 Japanese imported CR-Z.
Today I realised the DRL has not been working anymore. I had this external LED strip light installed by someone else for me a few years ago. I decided to change it, cut the cable, and install a new one. After I cut the cable I decide to finish up the next day, the DRL still working.
So I wrapped the red, brown and green cables together with some tape. Today I just realise my DRL is no longer working. My headlight, high beam and signal light are all working fine.
Does anyone know what happened or is the DRL fuse dead?
Automotive tire Motor vehicle Finger Hood Rim
The red line is where I cut the cable.
Car Vehicle registration plate Vehicle Grille Automotive lighting
My CRZ with DRL before installing external DIY led Strip light
Thanks in advance.
2014 Honda CR-Z EX CVT
Might buy a little circuit breaker to put in the place of the fuse. Then go mess with the wiring and see if you can trip the breaker.
1 - 6 of 6 Posts
