I have a 2011 Honda CR-Z that I have owned since late 2013. Love the car and all the goodies.
Recently, I had started to notice that my car was a little rank on the inside and I thought I just had to get it detailed and carpets cleaned and we'd be good from there.. that was not the case. After pulling out the carpet cleaner and going to town, I pulled out my driver's side floor mat which was just soaking wet and then noticed that the whole carpet on that side was soaking wet. Blah blah, just fast forwarding to the current status, I have pulled out the driver's side trim and the center console and pulled up just the driver's side carpet and have noticed that the foam insulation underneath is just socking wet with no other signs of puddling or anything of that matter. This goes for the foam insulation right under the feet and underneath the actual seat towards the back as well.
I am 95% certain that it is just water as I don't smell any coolant and didn't pull any coolant coloring when pressing some white paper towels against the soaking foam. I have been trying to search and search but I have yet to see anyone with this same issue.
There has been a good amount of rain recently but I have never noticed any leaks. I also did a small leak test the other day to see if I can try and spot it again along with spraying it completely down with a hose while being on the inside to inspect. Currently though, I have the carpet yanked up and a fan going to try and get this stuff to dry and not produce mold so I cannot do the hose test quite yet.
But anyways.. does anyone have any further insight here? I know I should start looking at the front windshield as a possible area and the driver's side window, but is there anything else that could be a contender into this problem? Also, I might just want to replace the foam insulation just to be safe and comfortable that there will be no mold growing, does anyone know where I can buy an OEM replacement or stuff that should work just the same?
I am very sad and annoyed and just hoping to try and get everything put back together but confident that it won't happen again. No other part of the car was wet, this is purely just the driver's side. I have been driving my car a little bit less just because I also got a truck recently, but it will never sit undriven for more than 2 days.
Any type of help would be greatly appreciated.
Thank you!
Thank you!
