1 - 2 of 2 Posts
2013 Base North Shore Blue 6MT
Now that summer's here I got a key for my CR-Z, it has a chip for the immobilizer but no remote transmitter buttons. So the plan is to use this key to manually open the driver's door and start the car.
My question is about fuses; is there a fuse I can pull so the remote lock/unlock function of the remote transmitter is disabled? I would still like the key to manually open all 3 doors with a 2nd turn, and I would still like the master switch to work. I would still like the immobilizer to work, and I would be happy with or without the security system alarm.
Any information you can give me about which door lock fuses do what will help, thanks!
2014 Honda CR-Z EX CVT
looks like these two fuses power the keyless receiver unit:
Rectangle Font Parallel Number Circle
*in the under dash fuse box
Note they might power other systems so might double check that when you look at the graphic on the fuse cover.
EDIT: there are several different circuit diagrams for the same year so not sure which is which. I'm sure other members will know though.
1 - 2 of 2 Posts
