I recently had my exterior drivers-side door handle break in the heat and discovered it is a common issue with the CRZ due to a poorly engineered part. I came up with a solution that matches the feel and function of the OEM part, and decided to share it here for anyone else with the same issue.
Tools:
If you don't want to worry about buying the individual fasteners or printing the lever arm, send me a DM and I will mail you a parts kit with some spares for $40
Printing Recommendations:
Material: ABS, ASA, or PC (PLA, PETG, and Nylon either have thermal issues or are susceptible to creep)
Minimum Total Wall Thickness: 1.5mm
Infill: 80% Hexagonal, Triangular, or Cubic
Step 1:
Remove the exterior door handle. There are many posts on how to do this and CRZOwner915 has an excellent video here. I do have some additional tips though.
Step 2:
Disassemble the handle. First remove the Phillips screw holding the cast aluminum block to the lever arm. You can then remove that piece. Now you should be able to push out the 5mm plastic pivot pin and remove the painted handle part.
Step 3:
To modify the original handle, cut off the original lever arm to where the plastic is solid. I did this with a Dremel, but use what you have. A hacksaw will work too.
Next you need to drill the post that's left 3/16" or 5mm right in the center about 8mm deep. Go slow and be EXTREMELY careful while drilling that the bit doesn't walk off center. If the hole blows out the side of the post, it will be difficult/impossible to salvage. I HIGHLY recommend that you first make a pilot hole with a smaller drill bit.
Step 4:
Using a soldering iron set to ~300°C heat and press the threaded insert into the drilled hole until it is flush with the top of the post.
After sinking the insert, it may bulge out the plastic on the outside of the post, so you might need to shave it down a little for smooth operation.
Step 5:
Install the printed lever arm using an M3x20mm button head machine screw, and reassemble the handle. Make sure the spring loaded white piece is on the proper side of the lever arm.
The final assembly should look something like this.
I haven't had a chance to evaluate the longevity of the printed part, but it is significantly beefier than the OEM lever arm and worst case, it is easy to print a new one and replace it again with the modified handle. I'm aware how much of a problem the door handle mechanism is, so I wanted to share my solution before waiting a year or more to test the parts. If you have any additional questions, respond and I will be happy to answer! I hope this is helpful to someone.
P.S. If someone wants to send me their broken handle to take better pictures of the process, I will repair it for free.
Tools:
- flat head screwdriver
- #3 and #2 phillips head screwdriver
- 10mm socket and ratchet
- 5mm hex key
- 2mm hex key
- Dremel with cutoff wheel or a hacksaw
- Drill with 3/16 or 5mm drill bit (1/8" or smaller bit is also recommended)
- Soldering iron (temp control is preferred)
Step 1:
- Make sure you are using the right size driver on the phillips screws. they are torqued pretty tight and easy to strip. especially with an impact driver.
- Remove the phillips screw next to the locking mechanism plug to remove the assembly.
- Be extra careful when removing or installing the bolts that hold on the exterior handle as they can easily fall into welded interior compartments in the door and become impossible to retrieve (ask me how I know).
- After removing the locking mechanism, plug the connector back in to keep your alarm from going off.
Step 2:
Step 3:
Step 4:
Step 5:
