Mirror Assembly Conversion
The mirror frame and mirror wiring harness need to be replaced in your stock door mirror housings to enable them for power folding. The mirrors need to be removed from the door to swap out the frames and new harnesses.
Door Trim & Mirror Removal
- Roll the windows down.
- Remove the trim pieces at the front and rear of the door glass.
- Remove the trim piece behind the door handle.
- Remove the cover inside the recess aft of the window switches.
- Unscrew the screws exposed in the two previous steps with a Phillips head screw driver.
- Remove the window switch assembly by gently prying it out with a trim tool and unplug it.
- Unscrew the screw exposed by removing the switch assembly.
- Carefully pry off the door trim piece using trim tools. There are (8) green clips holding it in place. There is a slot on the underside of the trim panel where you can start. Some of these clips may break, so having replacements would be a good idea. Unplug the courtesy light as you pull the door trim free.
- Unplug the mirror harness from the door harness.
- Pop out the mirror lens now while you have it secured to the car. Use a trim tool wrapped in cloth to gently pry it up from the bottom. Carefully unplug the mirror heater connections.
- Unscrew the (3) 10mm nuts holding the mirror in place.
- Remove mirror assembly from the door.
Door Mirror Disassembly
Once you have the mirror free from the car, the objective is pretty simple: switch out the existing mirror frame for the motorized frame and swap the harnesses. Disassembly is pretty self-explanatory and it's pretty easy to figure out without actually following the steps below. Be careful to not scratch the paint on the mirror housing, so have a towel or something under it while disassembling.
- Depin the mirror harness connector completely. Take a digital photo of the wire configuration to remember how everything goes back. The wire colors are same for the JDM harnesses.
- Remove the red electrical tape from the mirror seal and mirror harness.
- Remove the bottom cover on the mirror base.
- Remove the (3) T-25 Torx screws exposed from the previous step.
- Separate the mirror from the base, carefully pulling the depinned wires through the mirror seal and base.
- Remove the (1) T-25 screw exposed from the previous step and remove the adapter piece. This will be reused, so don't forget to attach it to the new mirror frame.
- Remove the (4) Phillips screws securing the black mirror bezel to the mirror housing and remove it from the mirror assembly.
- Remove the (3) Phillips screws securing the mirror actuator to the frame.
- Separate the mirror actuator assembly from the mirror frame and unplug it from the harness.
- Unscrew the Phillips head screw on the underside of the mirror housing securing the frame to the mirror housing.
- Remove the frame from the mirror housing while unplugging the mirror turn signal from the harness.
Driver side mirror before disassembly shown with lens removed.
Bottom cover removed and the T-25 screws exposed.
Removing the mirror actuator.
Disassemble the mirror down to this point and begin reassembling with the JDM parts. Passenger mirror shown.
Door Mirror Reassembly
The mirror should now be ready for reassembly. It will be reassembled in the reverse order of the steps above, except using the JDM mirror frame and harness. Be sure to remember that the driver's side mirror harness will have a GRAY sheath and the passenger side will have a BLACK sheath. If you switch the sides, the mirror tilt will operate incorrectly. Plug in the the small connector with WHITE and LIGHT GREEN wires to the motorized JDM frame before mounting it to the mirror housing.
When you have the mirror reassembled, repin the loose pins into the supplied connector or reuse your old one if you want. Lots of the wires are different lengths, so snap in the shortest wires and twist the longer wires ones around them to take up the slack, similar to how your original mirror harness is setup. The WHITE and LIGHT GREEN wires can be pinned into the two vacant sockets that are side-by-side on the connector. If you do not have the correct GREEN and YELLOW pins to make a PnP door harness, then you can leave the WHITE and LIGHT GREEN pins loose from the OEM connector to make your own wiring connections.
Once the mirrors are completely reassembled with the JDM parts they can be put back on to the car and bolted down. Leave the door trim off as you need to pull wires through the speaker opening in the next section.
Leftovers... notice how the mirror switch coincidentally plugs into the mirror harness...
