Power Folding Mirrors - Using the Mirror Switch
Power Folding Mirrors - Auto Retract Feature
Introduction
The JDM and some EDM versions of the CR-Z receive power folding door mirrors as a standard feature, while the USDM CR-Zs do not. Fortunately, this feature can be added to USDM CR-Zs by swapping a few parts in the door mirror along with the mirror switch and a little bit of wiring to connect it all. There are a number of ways to perform this conversion, depending on budget, but the basic idea is the same: two extra wires are needed per door mirror to connect them to the new mirror switch. The difference in the methods is in how everything is wired up; it can be either plug-and-play with a few extra mirror features or it can be basic power folding done as cheaply as possible or anything in between. This DIY is going to discuss mainly the PnP method of wiring up the mirrors, but it should still be useful for the more basic installs as well.
Parts Needed
Getting these parts in the US is possible, but they aren't exactly easy or cheap to get. Most of the parts in this DIY are only available in Japan, while some of them are available in Europe, but if ordering from the US it’s probably best to get them all from Japan. I get most of my JDM only parts from japanparts.com by using their online unlisted parts inquiry form. There are only three spaces for three parts on the form so you'd have to send a few inquiries to get all the parts you need. It'll usually take a business day or two for them to get back to you. They will recognize that all of the inquiries are from you and email you a link with all of your parts together on one page. Link to the inquiry page is below:
Inquiries for parts unlisted on our web site
Mirror Assembly Parts
Passenger Side Mirror Frame (76204-SZT-G21) - JDM/EDM part. Number [6] in the above diagram
Passenger Side Mirror Harness (76206-SZT-G21) - JDM/EDM part. Number [8] in the above diagram
Driver Side Mirror Frame (76254-SZT-G21) - JDM/EDM part. Number [14] in the above diagram
Driver Side Mirror Harness (76256-SZT-G21) - JDM/EDM part. Number [16] in the above diagram.
Mirror Switch Parts
Mirror Switch (35190-SWA-J02) - JDM/EDM part. Number [1] in the above diagram
Optional for a Plug-and-Play Harness
For the plug-and-play install as I have outlined in this DIY, I used these parts to make my harness to connect everything together. This method makes for a nice, clean install with the benefit of a few extra mirror features as well. The Honda Access parts are listed in the CR-Z “Interior” page on japanparts.com, so no need to send an inquiry if you are buying your parts from them.
Honda Access Auto-Retract Door Mirrors (08V02-SZT-000) – This enables the power folding mirrors to automatically retract upon locking the car and extend when the key is turned to accessory. The harness in this kit is useful for this conversion because it has a connection to the mirror switch with wiring that can be modified to enable power folding. There are also bits of leftover wiring to make the driver side door harness to connect the mirror to the main harness. This is a JDM only part.
Honda Access Reverse Tilt Passenger Door Mirror (08V08-SZT-000) – This enables your passenger side mirror to tilt down when reverse gear is selected. The harness in this kit has connections to the passenger side door harness and also has an unused connector pair with wiring useful for constructing the driver side door harness. This is a JDM only part.
Passenger Side Door Harness (32752-SZT-A10) - For a complete PnP install, I actually bought a USDM passenger door harness to sacrifice for two wires with the correct pins in order to connect everything through the OEM connectors on the passenger door. There are only enough pins to salvage from the two Honda Access harnesses to make one complete door harness, so this was only option to go that extra mile for everything to plug in using only stock connectors. Another option may be to try to get a LHD EDM passenger door harness and just swap complete door harnesses, since you are buying a door harness anyways; that might be pretty difficult to obtain for those of us in the US though. Otherwise, you can just bypass the door mirror connector and tap directly into power folding wires on the mirror harness for a 95% PnP install.
Documentation
These are the install manuals for the Honda Access kits that are used in this DIY. They are both in Japanese, but still do a pretty good job of illustrating how everything connects and gets routed through the dash. They also roughly show how all of the trim pieces are removed on the dash, so it's pretty thorough in illustrating what's involved with installing the harness in the dash.
Auto-Retract Mirror Install Manual
Reverse-Tilt Mirror Install Manual
Tools Needed
Basic Wiring Tools – Whether you are making a PnP harness or just running wires for barebones power folding, you will need to be able to splice wires, crimp connectors, etc. If you don't already have this stuff, you probably don't have the experience to tackle this project either...
Interior Trim Tool Set - You'll be removing a bunch of interior trim pieces and these will make it a lot easier.
Small Precision Flathead Screwdriver Set – These are needed to remove the larger pins from the harness connectors.
Small Needles – Some of the connectors use some really small pins and you’ll need a few of these to depin them.
Flathead Screwdrivers
Phillips Screwdrivers
T-25 Torx Bit
10mm Socket
8mm Socket
Small Zip-Ties
Extra Wiring – Preferably the wire colors should be GREEN and YELLOW.
Power Folding Mirror Conversion
The remainder of this DIY will be broken up into three major sections as follows:
Introduction
Parts Needed
Mirror Switch Parts
Documentation
Tools Needed
T-25 Torx Bit
10mm Socket
8mm Socket
Small Zip-Ties
- Construction of the PnP Harness
- Mirror Assembly Conversion
- Vehicle Install
