Pair of T10 4 LEDs - White
The blues worked great, but the storage light fixture is also aligned differently, so an LED wouldn't be aimed straight out towards the compartment - maybe that's why it's not bright enough there.
Pair of T10 4 LEDs - Whitedo you have a link to the ones that are too dim? I'm trying to decide which of the many different types I want to get or avoid.
are these the 1watt ones you talked about earlier in the thread?i just swapped out the license plate bulb for a set of white t10's that i got on deal extreme
Kreaper did the first list I think... and probably the best... I will add what I have to the first post just for you....so can we get a List on the first post of exactly how many of what type of bulbs we need to change all the interior lights + license plate?
i've seen about 3 different lists in this thread and none of them are the same.
Did you get these? It seems the T*10's are a little bigger than stock, will they fit? Which places are you using them in?FYI, here's what I ordered from Dealexteme. cheaper than ebay I believe.
takes about 2weeks shipping time to get it
DealExtreme: $3.15 Festoon 0.96W 4-LED White Cabin/Dome/Door/Glove Box Light (DC 12V)
Festoon LED $3.15/ea or $2.36/ea for 3 or more shipped
DealExtreme: $3.13 0.4W T10 1210 8-LED Vehicle Decoration/Signal White Lamp Bulbs (DC 12V/2-Pack)
T10 LEDs $3.13/pair or$2.34/pair for 3 or more shipeed
I just tested, mine come on when I open the door.so i finally got my bulbs a month later. i gotta stop buying stuff off ebay from China... takes forever to pass customs.
i replaced all of them except the ones above the "back seat" area cus i wanted to test them out as i replace them to make sure they're not on backwards.
I couldn't figure out how to turn those lights on. i thought they came on when you opened the door but they don't. what triggers them?
I changed mine during the day, but I verified tonight in case I was misremembering, but I'm pretty sure they always come on. I haven't even looked for any light settings, let alone changed them. Do yours come on when you hit the unlock button on your key??that's weird. i have no idea why mine don't.
could it be that the Canadian version comes on differently? or is it a setting in the dash options?
or does it only come on at night (using the same sensor as the headlights) since it was still day when i changed mine.
all the interior lights are T10 bulbs just like the license plate ones. the only different ones are the Dome lights which require a Festoon 31mm or 32mm bulb (either one will fit).Non of this makes sense to me lol I'm not very electrically inclined so can someone just tell me which to get with a link to the page lol. I already did my license plate lights, wanna order all the interior ones.
figured it out. where the Dome light is there's a switch "Off - Door - ON" and that setting determines how your interior lights behave. always off, only opens with the doors, or always on.I changed mine during the day, but I verified tonight in case I was misremembering, but I'm pretty sure they always come on. I haven't even looked for any light settings, let alone changed them. Do yours come on when you hit the unlock button on your key??
