1 - 20 of 225 Posts
Hey people, it looks like Photobucket killed my old account out there. The photos I had posted for this are gone, and I don't have them anymore. Sorry... CRaZee
Bulb Size Chart.
Headlights (low beam):
HID- D4S D4S HID Bulbs - D4R HID Bulbs | Lexus Xenon Headlights | HID Light Bulbs *have not tested these yet!
Non EX- H11 96 SMD HID Xenon White H11 H8 H9 LED Driving Lamps Fog Lights Bulbs
Headlights (High beam/ DRL):
HB3 9005 LED Bulbs plus DRL Decoder For Acura Honda Daytime Running Light *have not tested these yet!
Fog Lights:
Front Turn/Park lights:
7443 Dual Color Switch-Back 7443 7444 T20 LED Bulbs For Turn Signal Lights
Side Mirror Turn Signal:
LED
Brake/ Tail Light:
LED
Rear Turn Signal:
3156 18 SMD 3156 3157 LED Bulbs for Corner Light, Backup Light, Tail Light
Rear Side Marker Lights:
194 13-SMD 1210 T10 Car Automobile LED Light Bulbs 168 194 921 2825 I used a 5 SMD light on mine but this site does not have then in red from what I see, but these should work fine and will be brighter. These are behind a red lens so you should use a red LED.
Back Up Lights:
912 360¡ã 38 SMD T10 168 921 912 Bulbs for Parking, Side Door, Back up Lights
License Plate Lights:
194 5-SMD T10 Light Bulbs for Interior Map Dome Parking License Lights
Interior lights:
Dome Lights:
DE31 32mm Festoons
Door, Rear and Trunk Lights:
awsome! lol i just changed my lights to all red leds haha
Excellent DIY tutorial with pictures.... can you post before and after shots as well with what you replaced the lights with :thumbsup:
There are several other threads that have before and after pics.... as well as a complete list of the bulbs involved. That is why I didn't do that.. most people are just asking questions about how to get to the bulbs... hence my DIY.
Check out
http://www.crzforum.com/forum/do-yourself-articles/1036-diy-door-lights-replacements.html
http://www.crzforum.com/forum/j-racing/1684-t1r-led-dome-interior-lights.html
http://www.crzforum.com/forum/aftermarket-crowd/1879-led-switchback-park-lights.html
Kreapers CR-Z Bulb List
http://www.crzforum.com/forum/aftermarket-crowd/1879-led-switchback-park-lights.html#post13466
Discussion Starter · #11 ·
Got the LED's yesterday and swapped them for the licence plate. Went with 5-LED bulbs.
But they don't work! I tried pulling them and turning the bulbs around but still nothing......
Haven't actually swapped mine yet.. have the LED's.. just need to find time to do it.
Have you got any others that you can test with to see if they work? Or maybe plug the ones you got in the door lights, since they are readily accessible... just to test them? You might of got some bad ones...
Just got the dome LED's today. Here is a comparison:
and here it is with both in:
Now I am just waiting for the set of other bulbs to come in to swap out the rest. Took about 3 minutes to change them... hardest part was getting the tape off the bag the new bulbs came in. :)
Discussion Starter · #15 ·
Looks good!:thumbsup: Did you use the festoon based LEDs? Which ones? Got a link?
I ordered these ones off ebay... 7.99 for the dome LED. Ill have to find the link. Borcth set me in the right direction. I also ordered a set of bulbs for the other lights for $7 something for ten bulbs.
I figured a light bulb is a light bulb..so that's why I got them from ebay..
I replaced the rest of my lights today... managed to break one of the clips off of the license plate light though ... it still attaches on, but I will replace it when I take it into the dealer for an oil change. Makes a big difference in the dark -- looks way nicer with the white lights :)
so to do this , I will need 32mm "2" of Festoon bulbs and "6" of T10 Bulbs. correct? I will be ordering them from dealextreme.com :)
Yep! Just remember when putting in the festoon bulbs; they do have a neg/positive side. If it doesnt work one way, just turn it around. But Make sure the leds are always point down onto you. You should be good to go!
These are the ones I have. They come in a pair. They work great. I chose them because I liked the fact they were in cased in a housing. Unlike the other types which are open and exposed to the elements.
http://cgi.ebay.com/ebaymotors/32mm...Q5fTruckQ5fPartsQ5fAccessories#ht_3226wt_1165
If you want another style or more fancy. Here's a link to many different types.
http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=32mm+festoon&_sacat=See-All-Categories
As far as the T10 bulbs, yes 6 is all you need. But I tend to get a bit more for extra. Just in case you get one that's a dud. It does happen somtimes. I think a member one here already experienced some that didnt work no matter what way he put them in. I got a pack of 10 on ebay for a few bucks. They work great too. Better to be safe then sorry. Good luck!
32mm Festoon White 2-LED light bulb 3175 Dome Gauge Map - eBay (item 110555887572 end time Dec-02-10 19:15:36 PST)
I like this fact too about the bulbs I got
I ordered a set of 10 as well and had a dud in my set, so definitely get a few extra.
1 - 20 of 225 Posts
