1 - 3 of 3 Posts
Hello,
I would need procedure to replace radio by other equipment.
I don't want to hinge or bend anything, making a clean work.
The best would be to have the honda document covering the replacement of the radio cd player our how to equip the Alpine GPS.
can someone help me ?
There is a small black panel directly under the radio where the light is. Pop it off, front first. Drop that down and there is a screw that holds the radio in. After you remove the screw, pull radio forward. All clips!! Will take a good tug, those clips are strong, but it'll come out super easy :) Then get this and any Double din Alpine that you want. Navigation is super easy to hook up if you know how to install car stereos!!!!
https://www.al-eds.com/product.php?productid=23761#tabs
1 - 3 of 3 Posts
