DIY front LED strip
12042 Views 24 Replies 12 Participants Last post by  shawnfrontier
7
This is quite an easy mod - really a collection of a couple of mods already known. Bear in mind that certain colors (and flashing lights of the front) may well be illegal for on-road use in your jurisdiction!
I bought one of those "Knight Rider" LED strips, although this one actually has multiple colors and lighting configurations. I fitted it in front of the rubber seal that sits under the hood when it's closed. I popped the plastic clips off, then attached the strip using 3M tape, then replaced the rubber seal. This ensured that it was held firmly in place and wasn't pushing anything out of alignment.
It comes with a small black radio receiver that I mounted under the left side of the fender, also with 3M tape.
Drilled a hole through into the engine bay (I have a CVT so used the hole where the clutch stuff would go). Then threaded a wire through, spliced it to the positive of the receiver. The negative wire was grounded.
Screw in place where hole was drilled:
Screw seen from other side:
In the cabin, the wire was connected to a toggle switch I installed into the unused plastic cover next to the driver, that in Europe has a couple of switches on it. It was a tight squeeze but the switch fit - you could use smaller buttons if you want.
The other end then went to a fuse extender connected to fuse number 4 - for me this is always on.
Put everything back in place - it looks nice and tidy. Viola :D
21 - 25 of 25 Posts
Amazing Job man. Love your car
Thanks :) Tons I want to do to it...but now the mods are getting expensive. I have a shopping list topping $5k at the moment. So far I've probably put only $500 into it. Heh.
Heheh. i know the feeling!
I've started with some 80€ exhaust tip
Then 200€ Rim painted and repolished
Then a few bulbs....
Now the Sprintex ... now i got to slow down.....but am already thinking of grabbing a hold of some plasti dips....
It's like OCD crap or something-
I like the led strip, and the illumination mods, but in Portugal, they are very "strict/picky" with lighting alteration... otherwise i would go for a the grid mod. Keep it up man, i deffenently want to see more of this
My amazon "wish list" is growing :p
On paper what I'm doing isn't legal here in CT either - but no one seems to mind. I've had a few smiles and appreciative nods even from the police. I think the purple is bright enough that it's clearly not blue or red (definitely likely to get me in trouble) and looks close to an off-white. I can animate it too like Knight Rider but again...not sure if that's flashy enough to convince a cop to pull a U-turn and pull me over.
I got something planned for my car with the led scanner. Mine is going to be a little different than yours Bennett4490, just having trouble finding one that is 30" not the 22". The 22" will work but I don't think I would looks as good as the 30".
21 - 25 of 25 Posts
