1 - 20 of 295 Posts
so after realizing how boring and ugly our keys look lol, I decided to change my key to switch blade key.
Went to ebay and bought 3 button flip key shell for $10
and got keys cut at Honda Dealership: $10
since our keys have transponder built in in the electronic housing, it was direct swap without any modification.
Step1: Open up the original key: remove 1 screw and pop it open
Step2: Take out the button housing
Step3: Open up the flip key housing, it will want to turn clockwise. Turn it and Slowly seperate two halfs. Careful not to loose the spring or any other parts.
Step4: Fit the button housing and test all the buttons. For mine, I had to skim off the edges of the panic button hole.
Step5: Match up straight part of the spring and slot on the other half. Turn the other half 1 Revolution Counter clock wise. DO NOT turn it more than 1 revolution or you will ruin the spring. Close the housing and test the flip action before putting 3 screws back.
Step6: Carefully remove the original Honda logo from the original key and use some double sideded tape to stick it on the new housing
Keys Cut
And it Works!!
:hi5:
Thx! Just bought one!!
did you have to do any modifying to the chip? I've read that sometimes the transponder isnt close enough to the wheel and the car wont start - any issue like that with your mod??
cant wait!!!!
Hmm I am going to get the keys cut today so I will update you on that. one thing I had to modify was the hole for the panic button was a bit tight so I had to scrape the edges off with exacto knife.
great to hear but sucks because i just ordered the $100.00 ikeyless version.... plus i gotta pay for cutting and programming. you guys only have to pay $10.00 plus cutting....... oy vey!
1 - 20 of 295 Posts
