TOPIC UNDER CONSTRUCTION
(Waiting for different leds to compare, I am posting this so I don't forget stuff)
Difficulty: Easy
Costs: You can get nice leds on eBay starting from 4 dollar till..
What you need: little screwdriver, textile for protection, ..
Not under my responsibility
Difficulty: Easy
- When your door is open, put a small screwdriver with a bit of textile (for protecting the plastic) in the holes at the bottom of the transparant plate.
- There are 2 x U shaped clips, so you have to push that black doorpanel a bit away with your hands or a other screwdriver.
- After that you can tilt it over towards the inside of the car a bit in a certain angle (see picture) and then pull it down.
- Press the door controller (name?) to cool of the light
- After that you have to wiggle the light, its rotated in 45 degrees clockwise (so wiggle in that way, north east - south west)
- Now you can replace the T10 bulb with a other colored bulb or led. Max +/- 4 cm, so a lot of space left to use leds
