1 - 13 of 13 Posts
Quoted from Go Tunning Website:
Zero1 Coil
Description:
Fits 2011+ CR-Z models
Front Spring Rate: 6 kg/mm
Front Ride Height Adjustment: -45 - 0mm
Rear Spring Rate: 4 kg/mm
Rear Ride Height Adjustment: -45 - 0mm
*Custom Spring Rates available by request
Sport Zero1 is not compatible with e-con
Cusco Sport Zero1 coilovers are recommended for sporty or winding road driving. Sport Zero1 coilovers offer a comfortable ride while improving handling. Zero1 features fixed dampening force for a tuned and balanced ride. Optional 8-step adjustable rear dampening is available for adjusting driving feel when carrying additional luggage. The system is fully ride height adjustable for a wide range of height settings. Special anti-rust coating is applied to the height adjustment area for durability.
Zero3 Coil
Description:
Front Spring Rate: 10 kg/mm
Front Height Adjustment: -55 - 0mm
Rear Spring Rate: 9 kg/mm
Rear Height Adjustment: -60 - -35mm
*Custom spring rates available by request
Cusco Zero3 competition spec coilovers are designed for those with "S-type" tires. Zero3 features 24-step dampening adjustment with a needle type valve, full height adjustment, and a monotube shock with a large caliber piston. Best suited for circuit driving or long distance sports driving. Front camber is adjustable from -1 to -4 with multiple knuckle attachment holes to improve cornering grip.
Zero3 coil would be something I'd be interested in.
1 - 13 of 13 Posts
