Does anyone know if the 16" civic alloys, 6.5J ET55 will fit?
Have You got any photos of it in The rear?I went with the Spoon Blue color on my Axis Reverb wheels. They are identical to the Advan TCII wheels with the hollow spokes.
Wheels are 18x7.5 +45 with Falken 225/40R18
Overall Diameter is about the same.... Speedo reads 1 mph slower then stock.
Lowered on B&G S2 Lowering Springs. They have a great drop and ride very smooth.
It will... but not much imho.What do you think - will it affect mileage much?
The extra weight might have some negative effects to your fuel mileage but with a 205 Tire it's still fairly skinny so it shouldn't be too much of a hit.Just got for summer Pro Corsa 17"x7.5" offset 45mm with Conti Extreme Contact Sport Plus 205/45 R17 I think they look ok but I am wondering about gas mileage, 1 wheel (rim + tire) weights around 40 lbs and I do believe it is ~5lbs more that stock wheel and also larger and wider. What do you think - will it affect mileage much?
Yes that would be a spacer with its own studsLooking for final confirmation - It is one of two option but the other I would need to get a custom bolt pattern... gross.
Wheel info: HD Switch , 18x7.5, 42mm, - Whats the best way to push them out flush, ~20-25mm. Is that a spacer?
Tire info: going to try to snag some 235/35/18s for this, should help with rub.
Either should work, 215/45-17 is a touch bigger diameter than stock size but is closer to matching than the 215/40 which actually comes out smaller than stock. The 45 will help(a little) to fill that fender gap too.Hello guys and girls, new CRZ owner here
While i was looking for some sweet summer rims, I found these bad boys:
The sparco FF1 flowforged in 8x17" with a 40 offset:
I think they would fit my pearlescent white crz quite well, but now my question would be about the tires.
Im considering either 215/40 or 215/45, but honestly i have no clue which tire would fit better in terms of looks.
Do i have to worry about rubbing or is any fender work needed?
Also Im considering to drop the car later by maybe 25mm or 30mm (about an inch), cause right now it looks awfully high on the stock 16x6 195/55 combo.
Any suggestions and recommendations are appreciated.
What are the name of these rims btw? I couldn't find them.
