CR-V Navigation + JDM Reverse Camera Accessory on a USDM CR-Z
94250 Views 43 Replies 24 Participants Last post by  Scott Plantier
16
After some research into the various OEM nav units found in Hondas, I discovered that the 2010-2011 CR-V with navigation has a set of connectors that are almost identical to the CR-Z navigation unit, with the only exception being an additional input for a backup camera! The Honda factory installed cameras, such as the one found on the CR-V, and the Honda Access cameras, such the one available for the JDM and EDM CR-Zs, appeared to have similar wiring to each other. Provided that I could find a way to connect the camera to the head unit, I could have a 100% OEM backup camera setup without using a NavTool module. I found a used CR-V nav unit on eBay, along with the connector pigtails cut from the donor vehicle, and I snatched it up almost immediately. Problem solved.
Once again, instead of the usual DIY, I'll describe my install with a captioned pictorial:
Let's not beat around the bush. Here's the JDM camera installed on my bumper. Bumper removal required.
CR-Z nav unit shown on the left and CR-V nav on the right. The two have identical connections on the rear panel, except for the camera connection by the exhaust fan on the CR-V nav unit.
CR-Z volume knob vs...
...CR-V volume knob. This is the only difference between the headunit faceplates, besides the XM Radio markings (It still requires an external XM receiver).
The CR-V backup camera connector that was cut from donor vehicle harness.
Another nav unit connector from the donor CR-V. This connector has some pins with wires that better match the JDM harness wire colors...
...backup camera connector wires now color matched to the JDM camera harness.
Wires stripped before soldering. Original pins cut from the JDM harness shown on top.
Soldered and sleeved with heat shrink tubing.
This hole is where the wiring will pass through to the exterior behind the rear bumper.
The camera wiring has a lot of excess length. I also added my own wire looming to it, as it didn't come with anything that seemed long enough.
Harness running along driver door...
...past the rear tray/partition...
...under the IMA fan ducting...
...and finally to the rear with the excess harness length folded and zip tied to itself a few times.
I had to take most of the rear interior trim out to route the harness. I wasn't sure which side to route it to at first, so I took out both side liners to investigate...
Video of the camera in action:
The Honda nav units already have a reverse gear signal going to them, so just plugging in the camera connector enables the backup camera function. Pretty simple. Just put it in reverse and that's it. Removing the interior trim was the most annoying part of this install. Lots of the orange clips got destroyed when I removed the panels, so I still have a lot of my interior apart while I wait for replacements.
The only issue is that it seems that the screen viewing angle may be a tiny bit off for what's appropriate for the CR-Z seating position. It's not too bad though, especially since I can still play with the contrast and such to compensate for it. I actually tried swapping the headunit faceplates to see what happens with no success. The backup camera video will not display on the CR-Z faceplate; it just shows a black screen... Ah well. Other than this small issue, which you can correct with some adjustments, this mod was well worth it for me.
I didn't think this needed a full on DIY, since all information you need to do this is illustrated pretty well in the pictures. The part numbers that I used are listed below. There are a few other camera attachment kits with slightly different part numbers that are also available for the CR-Z which will probably work just as well; the difference is probably in what device they are designed to be connected to and the market it was intended for.
Anyways, this should be the last wiring project that I have planned for my CR-Z, that is until I find out about something else cool that involves wiring that I'm not yet aware of... Reply to this thread if you have any comments or questions. Thanks!
JDM Accessory Part Numbers
08A21-6H0-360 - JDM Camera
08B77-SZT-A00 - JDM CR-Z Camera Mounting Kit and Wiring Harness
  • Love
Reactions: 4
1 - 20 of 44 Posts
What's the part number of the CR-V navigation unit, for those who are starting anew?
The part number that's actually on the CR-V navigation unit label isn't the same as what's used by the electronic parts catalogs for Honda; the CR-Z headunit has a similar situation. Either way, only use it to confirm that you are purchasing the correct nav unit and not to buy one from the Honda dealer; that would cost you thousands instead of hundreds...
Also, getting one used from a wreck with connectors cut from the vehicle harness is the only way I know of so far to get the video connector. Perhaps, by chance, some other variant of the CR-Z camera attachment kit will have the correct connector for the nav, but I wouldn't rely on it...
Anyways here is a shot of the label on the nav unit:
The part number that I got from an electronic parts catalog is:
39540-SWA-336ZA
whacha doing with the stock navi?
If you have an EX, we can talk. The BASE model is more difficult to upgrade, because they don't have the external amplifier.
Also, I pulled the faceplate off of both units to swap them to see if I could improve the viewing angle of the screen. The screws strip very easily and I ended up with only one complete set of good screws between the two, which of course, I am using. The damaged screws are probably still usable, I suppose, but I think pliers would do a better job at tightening them at this point...
Awesome post. Nice find.
Sent from Tapatalk
Where did you source the camera and mounting kit?
Also, supposedly the 2013s will have backup cameras standard. Interested to see how they'll integrate these into non-navi models.
I get my JDM parts from japanparts.com, but that's only because I don't know anywhere else to get them from. I don't think I'm getting the best prices possible from them, but they aren't all that bad either. That's just what JDM stuff costs I guess...
With that said, if I could do it all over again, I would have tried a little harder to get the EDM SSD version of the camera kit (Part Number: 08A21-SZT-KIT1). I did a little more research into it and I think the connector from that kit will actually plug in in the CR-V nav with no splicing required. I found a picture of the back panel of one of the SSD nav units available in Europe for the CR-Z and there was connector that looked identical to the one on the CR-V nav. However, I have no idea how to get parts from Europe at all, so we may never know the truth on that one...
Here is the picture of the EDM SSD nav back panel with the connector of interest highlighted with a red box:
EDM SDD NAV part number: 08A40-2N6-400
i do in fact have the EX. i was the only other guy at the orlando meet with long hair besides you, had the white z with the loud p2r exhaust.
Oh, I totally remember you; I just couldn't remember if you had an EX or not...
Anyways, as far as the nav goes, I think it can be done, especially since I have the all of the connectors from the donor CR-V. We only need to add 2 connectors to enable everything and do a reconfiguration of the pins on one of your stock connectors; the other connectors just plug right in. We also need to add about 6 or 7 pins to your HFL module connector and wire them to the nav unit. I have a strong suspicion that they share the same pins, which is good because we'll have some extras from the other unused nav connectors. However, I'm not absolutely sure on the pins just yet since I haven't really looked at the HFL module with this mod in mind. There are also 3 wires going to the climate control ECU as well, but I think that might be more optional. If we have the right pins, might as well just do it.
You'll need to get the nav dash trim piece w/ brackets, GPS antenna, the HFL steering wheel switch with nav controls and maybe the aux-in jack if you want.
That basically sums up what needs to be done. I think it can be banged out in a day.
Anyways, as far as the nav goes, I think it can be done, especially since I have the all of the connectors from the donor CR-V. We only need to add 2 connectors to enable everything and do a reconfiguration of the pins on one of your stock connectors; the other connectors just plug right in. We also need to add about 6 or 7 pins to your HFL module connector and wire them to the nav unit. I have a strong suspicion that they share the same pins, which is good because we'll some extras from the other unused nav connectors. However, I'm not absolutely sure on the pins just yet since I haven't really looked at the HFL module with this mod in mind. There are also 3 wires going to the climate control ECU as well, but I think that might be more optional. If we have the right pins, might as well just do it.
The GPS antenna plug is the same as the one on the Kenwood DNX9980HD and the Pioneer Nav units. When I installed the DNX I just pugged the Honda GPS antenna in. So, you could get an aftermarket antenna. You wouldn't have to spend the bucks on the Honda antenna.
that sounds awesome. also, with ffearless' suggestion on the antenna, makes this that much more appealing. i'm up for this, and you really don't live far at all.
I had a feeling swapping a Nav from a different Honda would work (especially to add Bluetooth/Rear View Camera/DVD playback features), the only catch is finding one that's cheap enough to make it cost effective (as opposed to going aftermarket).
But I never thought anyone would do it!!!! ITEM9 you are amazing! Congrats on yet another superb mod!
How in the world did you find the pinout diagrams & part #'s???
Amazing, truly amazing!
Do you have a link to where you bought the camera ?
Pretty cool setup!
Does the CRV navi headunit have better display resolution than the OEM CRZ navi?
The Acura's look particularly sharp but I haven't studied the pinouts.
They are identical except for the camera input and maybe the screen viewing angle.
1 - 20 of 44 Posts
