Did a quick search on Hondapartsnow for ya. That small piece is not sold separately. The only way to get it is by buying a housing set. Make sure to select the correct body color before buying: Mirror - 2013 Honda CR-Z 3 Door BASE KA 6MT
Thanks! I'll check it out![]()
11 12 HONDA CRZ DRIVER LEFT POWER DOOR MIRROR SILVER OEM | eBay
Model: HONDA CRZ. HONDA CRZ 11-12 Power, non-heated, LH. Door Mirror. Door Mirrors. Door Trim Panels. Side: Left. We will need the VIN (and production date if necessary) from your vehicle and ID numbers if needed.www.ebay.com
her'es a silver one for you. it's a base model, but if you have the heated one you can swap the wiring harness over
I was thinking about that. Modelling the part would be tricky, as well as printing it since it'd need to be some heat resistant plastic like ABS.Thanks guys - Yes I though that only option is to replace the whole mirror. I'm actually thinking about doing 3d printing for this part, but have to check if there are such services in my area..
Hey! Really nice to hear from you, thanks!If you're still interested I have a mirror without the glass and with a warped cover. The black plastic is fine tho and it could be swaped over
Wrote an email to youHey! Really nice to hear from you, thanks!Yes, I basically just need the black plastic cover. Anywhere where I could reach you? My email is [email protected]
Marko
