1 - 5 of 5 Posts
2014 Honda CR-Z EX CVT
Might try taking it to a welder / fab shop and see what a quote would be to just weld it back on. Probably need to measure the seat bolt-hole dimensions before you go.
Don't abuse the report button
I've had seats break like this on other cars. When this happens, the entire associated frame gets damaged as well - in this case, the entire slide mechanism needs to be replaced. It is a safety-critical part.
You should replace the whole seat, since the slider frame is integrated into the base frame. It will also be easier and cheaper to replace.
1 - 5 of 5 Posts
