1 - 9 of 9 Posts
HA ! I was using the same video last week when I was working on my friend’s CRZ and I got stuck where I couldn’t remove the rear caliper. It turned out I had to loose the parking brake cable bracket on the torsion beam.
Discussion Starter #5
Damn that crz aint in good shape :(
I wonder if that rotor has the protective layer youre meant to wash off first. And i didn't see that important pin go back on :/
It was timelapsed so maybe just missed it.
Yea there’s some stuff i saw him skip over but I’d go ahead and replace everything he missed just in case. Though i heard the rotor screws can just be thrown away but everything else should be replaced with new or the original part
Yes sir.. screw those rotor screws! You will need to drill them out on yours anyways. Don't put them back or even bother with new ones!
Discussion Starter #7
I heard a manual impact driver can work as well along with getting a JIS screwdriver. But yea a drill seems to be the fastest way to get rid of those suckers
Yeah, you could also use a socket wrench + hammer to 'impact' it off / back on. But, its just as easy to get the pulley holder I guess. I just had the 12v around, and it made it simple since it doesn't go past 20 ft/lbs anyways!!
1 - 9 of 9 Posts
